Sponsored by: Real Truck
Fuel problem
Old Dec 5, 2024 | 03:17 PM
Larry00663's Avatar
Larry00663
Trailering
Angry Fuel problem
I have a 2007 F250 Super Duty Diesel. In the past, I would get a notice of low fuel warning, and it would show that I had 50 miles to go, and that was pretty accurate.
For the last 2 times when the low fuel warning, I could only travel approximately 1 mile before the engine would die, which means that I am stranded without any fuel.
Does anyone know what I need to fix the problem short of keeping it full before it gets below 1/4 tank?
Old Dec 5, 2024 | 05:11 PM
Pikachu's Avatar
Pikachu
The plastic pickup screen at the bottom of the pickup tube in the tank has probably broken off. It's quite common, actually. It isn't a particularly difficult fix, but you'll need to drop the tank.
EDIT: P/N is E5TZ-9J306-BA, I believe.
Old Dec 6, 2024 | 06:23 AM
Larry00663's Avatar
Larry00663
Trailering
Does this require any gaskets or seals?
Old Dec 6, 2024 | 09:12 AM
Pikachu's Avatar
Pikachu
It shouldn't if you have a poly tank with the spin on retainer for the sending unit, but while your at it consider doing the Hutch mod, or at least cleaning the screens in the mixing chamber in the tank. If you have a steel tank, look for signs that the inside tank coating is starting to delaminate.
Old Dec 7, 2024 | 04:53 PM
Larry00663's Avatar
Larry00663
Trailering
What is the Hutch mod?
Old Dec 7, 2024 | 05:21 PM
Pikachu's Avatar
Pikachu
Eliminating the in tank screens and mixing chamber and adding a filter outside the tank, before the pump.
Kristysangels
6.7L Power Stroke Diesel
Jan 16, 2023 10:34 AM
watson
6.4L Power Stroke Diesel
13
Apr 12, 2007 09:21 AM
MisterCMK
Mar 20, 2007 08:06 AM
matt10461
May 29, 2005 08:45 PM
trakman
Sep 26, 2004 11:45 AM
