75" Driveshaft??
Old Dec 4, 2024 | 06:57 PM
Albeix's Avatar
Albeix
75" Driveshaft??
As I build my 1979 F150 2wd with an 8' box and a built up 300-6 backed up by an M5OD-R2 I now discover that I need a 75" driveshaft. The truck came to me without a driveshaft and there appears to have been no provision for a two piece Driveshaft. I would like to go with a one piece shaft. On Line I can see one piece drive shafts from Ford Vans etc. as long as 80 inches.
Has anyone come across this issue and used a drive shaft from a different vehicle??. If so would you mind sharing what vehicle you found a shaft from.
Old Dec 5, 2024 | 01:09 AM
mikeo0o0o0's Avatar
mikeo0o0o0
I would just contact a shop that specializes in drive shafts.
They can make you one any length, any diameter and with any u-joints that you specify.
Old Dec 5, 2024 | 05:53 PM
NCHighBoy's Avatar
NCHighBoy
I've had a couple longer than that made. No vibrations; there are factors besides length that go into the consideration. Like the post above this, talk to a driveshaft shop and they'll let you know if a one piece will work for your application - or not.
Regardless of length, make sure your pinion angle is set correctly. Lots of YouTubes and Google guides on how to do it. It's a lot easier than it sounds first time you try it.
Old Dec 5, 2024 | 06:32 PM
Albeix's Avatar
Albeix
Took your advise and sent my requirements to a local driveshaft specialist. Got a reply almost immediately base cost before adding yokes etc is $1000 Cdn. This is a non starter so I will continue the search for a non F150 drive shaft that will meet the need. I know they are out there - They live among us.
Old Dec 5, 2024 | 08:10 PM
BLK79's Avatar
BLK79
Not sure if this will help but 2006 E150 van 4.6L with 4R70/75 trans uses a 4" aluminum one piece shaft that is 73" u-joint center to u-joint center, 74 1/2" end of tube, and longer counting rear axle flange and transmission input yoke.
Check Car-Part.com. I got one here locally in OKC from Riverside Salvage earlier this year for $100.
Old Dec 6, 2024 | 06:54 AM
Albeix's Avatar
Albeix
Thank you for chiming in. This is the response I was hoping for and yes it does help immensely! I got a local quote here in BC about having one made up and it started at $1000 Cdn BEFORE they added yoke's and u-joints.
Old Dec 6, 2024 | 09:08 AM
BLK79's Avatar
BLK79
If what I listed is too long, the same van with 5.4L is a couple inches shorter. Also those with E4OD/4R100 trans have a shorter driveshaft still. V10 even shorter, as does a heavier rear axle (D60 etc) has a longer snout that also "shortens" the driveshaft length.
Old Dec 7, 2024 | 07:01 AM
speedfreak78's Avatar
speedfreak78
Was that $1000 an all new driveshaft?
If you bring my local shop a used longer shaft, they'll shorten it and put all new u-joints in for a few hundred bucks.
You an always go to a pick-a-part junkyard with a tape measure and get something close that'll work. You might need conversion u-joints to make it fit, or you might need to swap yokes around.
Old Dec 7, 2024 | 07:13 AM
Albeix's Avatar
Albeix
Yes the $1000 was an all new driveshaft BEFORE they added in the yokes, U-joints and balancing. All said and done I would guess it would have ended up more like $1500 Cdn. At seeing that I am now going the used aluminum shaft route.
VirtualToaster
Jul 26, 2024 12:02 PM
winginit
Aug 10, 2015 08:55 PM
fulltimehiboy
Sep 22, 2007 05:30 AM
tonydlt
Mar 11, 2007 09:39 AM
tangcoral2004
Jun 30, 2005 12:39 AM
