I just picked up a 76 f100 ranger xlt, 2wd, 3 on the tree.
The odometer says 43,000 but I am pretty sure it’s rolled over. Engine (inline 300) runs great and has even/good compression etc.
Anyway, back on track…
The radius arm bushing are all cracked and shot. I searched here and found a sticky/thread but the pics aren’t loading anymore. I am looking for general info on what rubber bushings kits people use. I would like to all the bushing while I have those components apart.
I just noticed, 2wd. My "bad". If I had 2wd, I'd still look for polyurethane if keeping the truck long. I put my polyurethane in my 4wd in the '80s, no maintenance to it and never squeaks ... but the track bar bushings did eventually loosen up so replaced again.. I did it then to get a few degrees caster for straight line driving.
In further thinking, the poly likely last longer where it's just acting as a cushion or insulator, not actually being a "bearing" between two pieces of moving steel. A rubber bushing with bonded inner sleeve used at a pivot point like control arm end, etc, the inner sleeve moves with it's portion, but the rubber usually flexes to absorb the twist, not slide against steel under load.
I got a full poly urethane bushing/mount kit from LMC.
have you had any squeaking issue from the urethane? It’s going to stick truck so I was thinking the rubber would require less maintenance. Maybe I am dated in urethane technology nowadays.
still rebuilding, so not much drive time yet. Bushings come with a thick grease to help with squeaking
Not that you have the poly bushings, time to get a plan to get the radius arms pulled out of the frame mount (one at a time) to get the replacements installed. Are you radius arm frame brackets riveted or bolted on? AFAIK some people that have riveted brackets, remove the big nut and use a come along and pull the radius arm out of the bracket. Replace the bushing and then pull it back in. Once side at at time.
I know some folks like to remove the brackets and I have no idea why. When the radius arm bushings are shot, the pivot bushings likely are as well. I've done the pivot and radius arm bushings with the i-beams attached on one end and I've done them by pulling the i-beams out from under the truck. I don't see how removing the brackets gain anything unless a fellow wants to do it with out removing the tire and brake assembly. I figure, might as well do the king pins and repack the wheel bearings while I'm in there so the tires and brakes come off anyway.
this is the way I was leaning, I know the arm and pivot bushings need replaced. I figured, like you, if I take everything apart I can redo bearing, inspect king pins, replace the rubber brake hoses and lube everything.
