4x4 issue
Old Dec 1, 2024 | 09:09 PM
Pikachu's Avatar
Pikachu
I'm sorry, but I don't believe the dielectric grease was the cause of any problems.
Old Dec 1, 2024 | 09:24 PM
John in OkieLand's Avatar
John in OkieLand
Originally Posted by John in OkieLand
NEVER put Dialectric Grease on connections, it is an Insulator.
[QUOTE=Pikachu;21417609]This is a myth. Applying dielectric grease to the pins and sockets of a connector in good mechanical condition presents no problem.
you might think it is a myth, but I worked as an IT Tech for 60 years, and I have seen my share of problems caused with dielectric grease on/in connections. just don't do it.
the manufacturers plainly state, to use it to seal out moisture, not inside the connections.
Old Dec 1, 2024 | 09:44 PM
INFRNL's Avatar
INFRNL
I don't remember how to do it but you can jump the relays to engage/ disengage 4x4. IIRC, it doesn't matter what position the esof switch is in. This could tell you what direction the problem is in. it's very possible you just need a new actuator, IDK. it could be a number of issues.
Old Dec 1, 2024 | 11:30 PM
F350towing's Avatar
F350towing
We can agree to disagree on this.
I had a smooth steady idle.
Used dielectric on the CPS, IPR, ICP, EOT, and so on, idle was rough and hunting.
Cleaned the dielectric off the contact points and used conductive grease. It has NEVER idled this smooth.
To the OP… sorry for the thread hijack.
1998F150XLT
1997 - 2003 F150
Mar 6, 2018 11:03 PM
Pitsingerk
2004 - 2008 F150
Jan 7, 2013 06:19 AM
diggler1971
1997 - 2003 F150
Sep 19, 2012 12:59 PM
SkorpioN
1997 - 2003 F150
Dec 18, 2004 12:03 AM
