Stuttering acceleration
Old Nov 26, 2024 | 10:46 AM
Blastzone's Avatar
Blastzone
So I have done many things to try and fix this problem but I can't seem to figure out what's causing the stuttering.
- new ICP and IPR sensors (motorcraft)
- fresh oil and fuel filter
- sending unit is clean
- good fuel pressure
- new IDM
- used forscan and has no codes and values seem to be right
It only start sputtering only while driving and going above 2000rpm and the engine is warm.
I'm starting to get lost here and am needing help.
Old Nov 26, 2024 | 01:01 PM
Kintla's Avatar
Kintla
Asked about codes and then saw you said no codes.
With no codes and more prominent under load (above 2k) I'd be thinking fuel related.
How do you check fuel pressure?
Old Nov 26, 2024 | 01:06 PM
Blastzone's Avatar
Blastzone
I hooked up a fuel pressure gauge to the fuel bowl where the fittings are
Old Nov 26, 2024 | 01:07 PM
Kintla's Avatar
Kintla
Can you check pressure while driving or just at idle?
Old Nov 26, 2024 | 01:10 PM
Blastzone's Avatar
Blastzone
Both and got around 60-70 psi
Old Nov 26, 2024 | 01:19 PM
Beechkid's Avatar
Beechkid
IMHO, bad fuel would be my next issue to check out
Old Nov 26, 2024 | 01:23 PM
Blastzone's Avatar
Blastzone
I don’t think that would be it cause we filled up my moms 2500 the same day and it’s running fine
Old Nov 26, 2024 | 01:24 PM
Blastzone's Avatar
Blastzone
The last things that come to my mind have been the ICP connector or air in the high pressure lines
Old Nov 26, 2024 | 03:40 PM
Wes444's Avatar
Wes444
Oil level?
Old Nov 26, 2024 | 03:41 PM
Blastzone's Avatar
Blastzone
At the allowed max
Originally Posted by Wes444
Oil level?
Old Nov 26, 2024 | 09:36 PM
udsuth78's Avatar
udsuth78
Aeration,if it's only stuttering while driving I'd guess it fuel aeration, but until verified I wouldn't take oil off the table.
Old Nov 26, 2024 | 09:41 PM
z31freakify's Avatar
z31freakify
Have you ruled out HPO leaks? Could be a bad Injector O ring causing it
Old Nov 30, 2024 | 04:02 PM
Blastzone's Avatar
Blastzone
Ok
how would I go about finding a hpo leak and my icp is reading 468-492 psi at idle(op temp). At 2000 rpm it’s fluctuating about 300-400 psi
Old Nov 30, 2024 | 04:23 PM
udsuth78's Avatar
udsuth78
What's IPR DC% at idle? Warm engine oil it should be around 8-10. If it's 14+ means you might have a leak. That's just one quick and dirty check. There are more accurate tests if you decide you need to investigate further.
Old Nov 30, 2024 | 04:32 PM
Blastzone's Avatar
Blastzone
Darn it is. I’m guessing YouTube has some good videos on it
