Fuel injection?
Old Nov 26, 2024 | 07:48 AM
oceanrace's Avatar
oceanrace
Fuel injection?
Does the 7.3 gasoline engine utilize only throttle body fueling, or does it also use direct injection? I thought it was throttle body only. Is it necessary or desirable to add a PCV circuit oil vapor catch can?
Old Nov 26, 2024 | 09:29 AM
FishOnOne's Avatar
FishOnOne
The 7.3 using the reliable Sequential Port Fuel injection design. Should not need a vapor catch can.
Old Nov 26, 2024 | 11:58 AM
acdii's Avatar
acdii
TBI went out of style in the 80's for Ford V8's, GM still used it through the 90's if not longer. Pretty much every non DI engine is SPFI.
Wont be too much longer before I tear into my 2014 Flex and find out just how good the Ford patent is for their self cleaning DI valve system is. I have to replace the chain tensioners which requires pulling the intakes off, so I will be able to inspect all the intake valves.
Old Nov 27, 2024 | 08:08 AM
willynilly's Avatar
willynilly
who wants to replace chain tensioner every 10yr. should of got yourself a toyota
Old Nov 27, 2024 | 10:59 AM
Dustin F450's Avatar
Dustin F450
Mrs nilly,
I hate to tell you ma'am but Toyota isn't now what they once were. The 3.5 2GR-FKS Toyota needs the timing cover resealed, have needle bearings that need replacing on Tacoma 4wds. I own a 23 Tacoma and they are FAR from maintenance free.
Old Nov 27, 2024 | 11:25 AM
acdii's Avatar
acdii
Had a Toyota, 2007 RAV4. It needed a full timing chain replacement at 178K miles. After sitting a day, starting it required bumping the key a few times or it would rattle like it wanted to blow up. Toyota is no more reliable at 180K than Ford is. That car is on its last legs too, was lucky to sell it as it has so much rust it can't be lifted by its lift points. The Flex Ecoboost just rattles a little after sitting a week, but if driven every day no rattles at all. My Flex can easily go 10 more years and still look like new.
dirtmonkey11
Jan 31, 2010 05:38 PM
SUPERDUTY_untouchabl
2004 - 2008 F150
Mar 23, 2008 09:36 PM
beefFX4
2004 - 2008 F150
Jan 21, 2005 06:54 PM
nastruk95
Aftermarket Products
Mar 25, 2004 08:25 PM
