Which oil filter with BPD setup are you using ?
Old Nov 23, 2024 | 08:11 PM
billbot's Avatar
billbot
My truck is about due for an oil change, just hit 190k miles last weekend.
I have seen some info on the Wix being a bad choice in replacement. That's all I've used since I put the BPD air/ oil cooler on years ago so I'm a little bothered by that.
So which filter is anyone using with their setup? I don't have the oil bypass just the old school remote filter.
I was considering the Baldwin BT349. Seen it recommended over on another forum.
Also Carquest 85832 might be ok? Seems to now be made by the same parent company as the Baldwin but maybe slightly inferior.
Another option may be the Donaldson P551604 but not sure with the flow rate.
Any others anyone might recommend?
​​​​​​Going to give BPD a call on Monday.
Old Nov 24, 2024 | 08:07 AM
tfunk88's Avatar
tfunk88
Racor from dieselfiltersonline
Nevermind, just realized you have a spin on filter
Old Nov 24, 2024 | 08:29 AM
joe blow's Avatar
joe blow
Baldwin BT349 for years!
Not one issue and they are sold everywhere online.
Old Nov 24, 2024 | 08:01 PM
billbot's Avatar
billbot
Thanks
Sounds like that's the one people are using now. Hopefully pick one up tomorrow somewhere local, bunch retailers close by
Old Nov 24, 2024 | 08:34 PM
joe blow's Avatar
joe blow
Nice. Good luck and don't forget to pre-fill the filter but I am sure you have done it several times.
Old Nov 25, 2024 | 08:15 AM
npccpartsman's Avatar
npccpartsman
WIX 51832 from Filter1. Order 2 at a time and they are (or were) cheap. IIRC they're the same as the Carquest but, regardless, they work great. I changed my oil every 5K and filter every 10K. It was still running with over 400K miles last time I talked to the current owner. I sold it at 325K.
Old Nov 25, 2024 | 03:54 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Howdy Timbo!
What did you end up replacing it with?
Old Nov 25, 2024 | 05:50 PM
bismic's Avatar
bismic
A nice F150, but there are still post-partum blues from what I hear anyway!
Post a pic Tim, if you don't mind!
@npccpartsman
Old Nov 28, 2024 | 01:51 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
WIX 51832
Same here ..
hydrosmith
1978 - 1996 Big Bronco
Feb 28, 2011 05:34 AM
lazyscholar
Feb 24, 2008 12:22 PM
Learath
Aug 23, 2006 11:29 PM
numocystic_10
Oil & Lubrication
42
Jul 12, 2006 11:34 AM
fordsrgrt
Oil & Lubrication
May 9, 2006 05:34 AM
