Sponsored by: Auxito
Help! Broke a lugnut stud
Old Dec 1, 2003 | 05:44 PM
Fordtrucktexan's Avatar
Fordtrucktexan
I couldn't beleive it when it happened, I rotated the tires today and when tightening the lugnut on the driver's side rear wheel, the stud broke off. Anyone ever had to replace one?
Old Dec 1, 2003 | 06:14 PM
triton_2002's Avatar
triton_2002
What size wheels/tires are you running? I'm assuming you're not running stock wheels if you have a lift. My brother's got a Z71 with a 9" lift and 37" superswampers, he's broken a couple of wheel studs. I'm guessing the extra weight and stress takes its toll on the stock studs. It shouldn't be too hard to fix, but I've never done it, so don't take my word for it!
Old Dec 1, 2003 | 07:54 PM
Fordtrucktexan
It's possible the tires had something to do with it, but I've seen people run much bigger and never break one, plus these trucks came from the factory with the size I'm running (4x4 versions) so it's not like I'm stressing my machine out. I'm about to go back to stock size anyway because of the power loss in running taller tires.
Old Dec 2, 2003 | 07:54 AM
karenj's Avatar
karenj
Hey fordtrucktexan, a-lot of broken studs are from over torquing lug nuts. Between 90and 105ft lbs is in the ball park for your lug nuts. As far as replacing a stud, I have'nt had to change one for a LOONNGG time.Old fashioned method, brass drift,large hammer,punch out brocken stud,put new one in and use lug nut to re-press. Don't know if this method would still work on newer vehicles.Have to be careful when doing this on the truck due to bearings and seals could get damaged.If not take it to your local tire shop, they replace them using a stud tool. Hope this helps.
Old Dec 2, 2003 | 08:01 AM
JeremyH's Avatar
JeremyH
I believe that most lug nuts are still pressed in. If not then they are screwed in.
Old Dec 2, 2003 | 10:24 AM
dcat14's Avatar
dcat14
Im with karenj...most are still pressed in and this should work fine. tire places break em more often than you'd think. Take a quickj look all around to make sure there isnt a set screw and thats it. Will take some elbow grease but nothing terrible...maybe soak some PB on there first.
Good luck.
Old Dec 2, 2003 | 03:45 PM
BobKoos's Avatar
BobKoos
I haven't replaced one of the ford truck, but have done a few on other cars recently and they were pressed. I would suggest you head down to the parts store and get a new one to be sure.
If it is pressed you just hammer it out from the front and then put the new stud in, and pull it into the hub using a lug nut and a couple of heavy washers as spacers.
Old Dec 6, 2003 | 05:07 PM
Steve02's Avatar
Steve02
Having replaced about 8 lugs on an Eclipse, I can say that an air impact gun will work magic on setting the new lugs into place.
Old Dec 7, 2003 | 12:18 AM
Fordtrucktexan
Got it replaced Thurs, even for me this was dirt simple and took a whole minute to do. Thanks a ton for the info everyone!!
Bundy34
Mar 10, 2012 01:42 AM
JD717
General Automotive Discussion
18
Dec 29, 2005 12:22 PM
rebocardo
All Things Towing
Sep 21, 2004 04:12 PM
rebelford
Aug 27, 2002 09:25 PM
