Sponsored by: Auxito
Pinging valves
Old Nov 19, 2003 | 10:26 PM
Eddieslilmule's Avatar
Eddieslilmule
Question Pinging valves
Hello all
I have a 1997 F150 with a 4.6 and i can hear the Valves pinging when i give it on the gas. Could it be the type of gas.
Old Nov 20, 2003 | 08:04 AM
Rodburnr's Avatar
Rodburnr
I have a 97 F-150 with the 4.2 in it. I just had a new engine put in buy ford about 2000 miles ago. I had the same problem with in the last couple of weeks. I started putting the mid grade fuel in the truck and it did help some. I have since moved up to premium fuel and do not have the problem anymore. I am still going to go back to ford and ask them though about the situation. According to the owners manual, 87 octane is what they recommend fot my truck.
Old Nov 20, 2003 | 09:21 AM
98f1504x4ohio's Avatar
98f1504x4ohio
I noticed my 98 4.6 doing it sometimes after the trans shifts, so I put a bottle of STP injector cleaner in it last night. I'll let ya know what happens, but in the meantime, I'd change gas stations, and NOT use any higher octane fuel. you could burn holes in the pistons!!
Old Nov 20, 2003 | 02:25 PM
Hoosier_Daddy's Avatar
Hoosier_Daddy
Re: Pinging valves
Originally posted by Eddieslilmule
Hello all
Hey Eddie! Yes, it is the gas you are using!
I've got a 98 NASCAR Edition F-150 with the 4.6 as well. I know your manual may tell you that it's ok to run 87 octane but they also fail to tell you that it will cause your valves to ping.
I work for a Ford dealership in Kentucky and this is a common complaint. Running a higher octane fuel like 91-93 octanes will most definitely fix this problem I'm not so sure about the info 98f1504x4ohio left about the pistons (no offense).
Anyway, I strongly recommend running 91 octane or higher at all times for the best performance out of your truck. I bought my truck brand new in 98 and I've ran 91-93 octane since the day I bought it and now with almost 98k miles on my truck I've had ZERO problems out of my truck and no VALVE PINGING
Hope this helps!
Old Nov 20, 2003 | 07:58 PM
Racerguy's Avatar
Racerguy
It actually doesnt have anything to do with the valves. You have preignition or detonation as some people call it. Basically the fuel is igniting in the cylinders before it should be. It could be caused by ignition timing being too far advanced however that isnt adjustable anymore. It could also be caused by a piece of carbon in the combustion chamber getting red hot and igniting the fuel before the spark plug does. There are other things too but thats the basic idea.
Sometimes a good run on the highway to clean out any carbon will help.
Better gas will usually help.
Quite often a dirty MAF sensor can cause a ping as well. It makes the trucks PCM (computer) not know exactly how much air is going into the engine so it adjusts the timing and fuel based on an incorrect signal.
Old Nov 20, 2003 | 10:43 PM
LxMan1's Avatar
LxMan1
Hey Hoosier Daddy, Which dealer do you work for? I want a second opinion on my idle vibration.
Jimmy
Old Nov 21, 2003 | 12:32 AM
F1 Ford's Avatar
F1 Ford
Add me to the list of pinging 4.6L ('97 S-cab 4x4). I would agree that it is pre-ignition knock as mid-grade fuel seams to provide enough burn resistance to shut it up, it'll get premium for boat pulling as there is still a hint of ping with mid-grade. I really love this truck, but I'm a little disapointed that I can't burn the cheap gas.
Old Dec 6, 2003 | 03:13 PM
FordTuff1's Avatar
FordTuff1
Well i have a 1998 f-150 ext-cab and if i use regular gas mine pigs as well even though the manual says use regular gas if the ower before you used high octane gas it will make the ping noise when u use reg. gas.I also try to fill up with super then when i get to half take i use reg. gas then when that gets back down to half a tank i fill back up with super,the gas treatment is also good to use every now and then.Good luck and let me know how you make out.
Old Dec 6, 2003 | 04:20 PM
mars's Avatar
mars
how does one go about cleaning the MAF sensor? i've had the same problem w/ my 4.2. and running higher octane fuel got rid of the pinging.
Old Dec 7, 2003 | 01:06 AM
Racerguy's Avatar
Racerguy
mars take a look at the FAQ's at the top of the forum for a link to instructions.
