Sponsored by: Auxito
Need h Eli with2002 f150 key problem
Old Nov 19, 2024 | 09:59 PM
pretty little hotrods's Avatar
1st Gear
Drilled out lock tumbler, now won’t start,turns over, no fire. Think I tripped the pats buy using the door key without the chip to try and start it.please help advice
Old Nov 20, 2024 | 03:51 AM
manicmechanic007's Avatar
manicmechanic007
Use a programmed PATS key?
And try it again
Use a scan tool and see if pats is actually disabling the start function
Old Nov 20, 2024 | 01:00 PM
BareBonesXL's Avatar
BareBonesXL
"Tripped" PATS will reset after about 15 minutes. Wait unitl the light is flashing slowly, about once per 2 seconds, then use the right key.
RalphCarter
2009 - 2014 F150
Jan 4, 2024 05:16 PM
muratet
May 16, 2023 08:34 PM
94xltsc
Nov 26, 2014 05:40 PM
Stuart7
General Automotive Discussion
Aug 26, 2014 04:48 PM
mikefox670
1997 - 2003 F150
Mar 2, 2005 07:36 PM
