Blower motor
Old Nov 19, 2024 | 01:08 PM
mlentz28's Avatar
mlentz28
4th Gear
Blower motor
I have seen a user post this same issue that I’m having but apparently he never logged back on after his initial post so I don’t that a resolution was ever found. Any help would be appreciated!
Problem is that my blower motor harness was getting to hot or it arced, melting the wiring harness to the posts on the blower motor so I replaced the motor and harness and when I wired it back, there are two heavier gauged wires, one black and green and the other yellow and green. There are 12 volts minimum with these two wires but the small communication wire is not providing any power thus the blower will not blow…can anyone please help?
Also, those who make this site possible and who give their time to make this site what it is, are great guys for your service so thank you in advance!
Old Nov 20, 2024 | 04:18 PM
2019er's Avatar
2019er
Thank you. Was it hard to get to?
Old Nov 20, 2024 | 05:07 PM
mlentz28's Avatar
mlentz28
4th Gear
Was what hard to get to?
Old Nov 21, 2024 | 04:10 PM
dmamfmgm's Avatar
dmamfmgm
At 1:48 in this video, you can see which wires go into the plug:
I recently replaced my blower motor using this video as a guide. I'll try to write down the plug wiring diagram, looking at the plug from behind (as if you're holding it and ready to plug it into the blower.)
Code:
TOP
+ Black/Green. + Empty ...... |
+ Yellow/Green + White/Purple |
The White/Purple wire is the skinny wire.
About the blower being hard to get to - I had to take off the side panel cover, then detach the 4x4 control module so it can be moved slightly.
That 4x4 control module is held on with two 10mm bolts, one in front (easy to get off) and one in back (super hard to reach). Fortunately for me, the previous owner of the truck had already been working on this, and so the bolt in back was only finger-tight.
After that, I could get my tools to reach the torx bolts holding the blower to the top of the front passenger footwell. I admit, I had to go buy a 90-degree angle driver and put my screwdriver bit on it, and even then it took me a couple hours of attempts before the torx bolt at the very, very back came out. So if I were to do it again I would first remove that back one while the front two torx bolts still hold the blower up.
HPRifleman
Feb 16, 2023 08:24 AM
trailhead2004
Dec 9, 2017 05:50 AM
Ford99508
2004 - 2008 F150
Jan 9, 2017 04:59 PM
mikeinri
13
Jul 5, 2015 10:44 AM
1980 Ford F-250
Jan 25, 2013 12:40 AM
