Serviceable catch can
Old Nov 18, 2024 | 11:29 AM
jimzpsd's Avatar
jimzpsd
I sure am glad I went this route for my home made catch can. Two trips to Kentucky (a beautiful state) from Wisconsin...22 days of fun and 3200 miles. Once home, I drained the "water " and removed the lower portion of the cc...not only a pint of water but all this crud. No way would I want a drop of this junk going back into the engine not to mention the clean and dry intercooler pipes.
Old Nov 18, 2024 | 11:50 AM
JoeUser's Avatar
JoeUser
Ugh, that's nasty stuff. Makes me wonder whether I should go forward with adding the catch can that I have (that I haven't installed yet, need to fashion some kind of bracketry). Seems like not allowing the vapor to condense in a can is the less messy alternative... But, I reckon I should install the can eventually.
Old Nov 18, 2024 | 01:23 PM
jollyrogr's Avatar
jollyrogr
That's basically an emulsion of water and oil (like mayonnaise). I agree it makes sense to keep it out of the engine. What's your catch can install look like?
Old Nov 18, 2024 | 03:00 PM
jimzpsd's Avatar
jimzpsd
I'll have to search, I posted pics in a different thread. Basically made out of 4" PVC tubing about 6" tall, capped on both ends, vent holes on top along with the ccv hose nipple, bottom has a drain port and is also removeable. Beats installing these (high dollar) catch cans made of CNC aluminum, they still vent back to the motor making them pointless, like I said I don't want to see a drop of this crud in my engine.
Old Nov 19, 2024 | 10:35 AM
ZooDad's Avatar
ZooDad
Retired guy fixn stuff
Here is the link to the thread with photos
Catch can v2
ZooDad
Old Nov 19, 2024 | 06:07 PM
Sport45's Avatar
Sport45
The stuff in the bucket looks bad, but in a matter of speaking it’s not as bad as it looks. Our unmodified engines can and do last many hundreds of thousand miles with only routine maintenance. The vapors that are recycled through the ccv system are vapor phase and not the congealed mess you will see in a catch can. What the engine sees is water vapor (a product of hydrocarbon combustion) and hydrocarbon vapor mixed together and consumed while still in vapor phase.
That said, I have nothing against anyone using a catch can. I’m sure my 2-stroke power equipment spews much more oil and unburnt hydrocarbon into the atmosphere. I just wanted to put it out there that catch cans aren’t keeping the muck you see out of the engine. That muck is a result of the catch can allowing the vapors to condense together.
Old Nov 19, 2024 | 07:09 PM
jimzpsd's Avatar
jimzpsd
Understood, and I realize the mess looks worse.........but its the moisture side of it mixing with the EGR gases that create the black goo I'm avoiding.
Old Nov 20, 2024 | 08:10 AM
jollyrogr's Avatar
jollyrogr
ZooDad
I think you forgot the link.
Old Nov 20, 2024 | 08:20 AM
jimzpsd's Avatar
jimzpsd
If I have time today, I will take a couple of pics for you of the installed unit.
Old Nov 20, 2024 | 09:41 AM
ZooDad's Avatar
ZooDad
fixed
when I changes the title it deleted the link and I didn’t catch it.
thanks
ZooDad
Old Nov 20, 2024 | 11:40 AM
jimzpsd's Avatar
jimzpsd
Pics
Old Nov 20, 2024 | 12:25 PM
jimzpsd's Avatar
jimzpsd
fixed
thanks
ZooDad
Thank you very much
Old Nov 20, 2024 | 12:54 PM
jollyrogr's Avatar
jollyrogr
Thanks @ZooDad and @jimzpsd !
Some questions before I get started,
1. Do you ever smell the vapors in the cab?
2. How did you connect it to the engine? Did you connect to the factory CCV hose somehow and then put some kind of plug on the intake port?
Old Nov 20, 2024 | 02:01 PM
ZooDad's Avatar
ZooDad
@jollyrogr
I would think something like this would work
CCV reroute (eBay)
SPE Motorsports
SPE Labs
ZooDad
Old Nov 20, 2024 | 04:00 PM
jimzpsd's Avatar
jimzpsd
I did the exact same one as the e-Bay unit. Sure it might be chinese, but I'm sure the other ones are too. So the cheapest price got my cash. Install was a breeze too.
