Sponsored by: Real Truck
AC issues??
Old Nov 17, 2024 | 09:42 AM
MSG Marine's Avatar
MSG Marine
4wd High
AC issues??
I have a 2000 F350 with the 7.3. It has 215k with no mods.
I made a stop at the local Kroger this morning and decided to pop the hood and check the oil. When I raised the hood, I heard a hissing sound and narrowed it to the passenger side to the engine compartment.
I noticed the hose going from the back of the AC compressor was dripping condensation. When I felt it it was cold as if the AC had been running.
well it’s in the 50’s here and I was pretty sure I didn’t have the AC on, but checked anyway. As it turned out I was correct, the switch was set on the split between floor and dash and the temp selector was between hot and cold.
I turned the switch to off so neither AC nor heat was in play and drove the same distance home and checked the hose from the AC again. There was no hissing heard, the line was dry and ambient temperature.
I’m ignorant on anything air conditioning related, I admit that, but I’m pretty sure the compressor should not be running while the AC section of the switch isn’t selected.
my question is, where my first jump off point to check? The switch, the compressor? Or are the super duty’s known to have, what I’ll call a hiccup now and then where the AC somehow gets turned on when it isn’t wanted?
Old Nov 17, 2024 | 10:32 AM
GOT-DRT's Avatar
GOT-DRT
I believe anytime defrost is on the A/C compressor comes on
Old Nov 17, 2024 | 10:46 AM
MSG Marine's Avatar
MSG Marine
4wd High
Well that could get costly with fuel mileage. I guess in winter a guy could unplug the AC compressor so it’s not running all the time.
Old Nov 17, 2024 | 11:24 AM
Ted722's Avatar
Ted722
Normal operation. But, not explained in manual. Try Vent or Floor only, shouldn’t engage AC.
Some threads on this over the years. Example:
https://www.ford-trucks.com/forums/1...his-right.html
Niki Farmgirl
Jun 9, 2018 06:21 AM
Terry SD
6.4L Power Stroke Diesel
Jul 11, 2014 12:34 PM
6CylBill
Jan 11, 2009 10:18 AM
AK-Excursion
Jul 7, 2008 08:09 AM
mike3000sx
May 21, 2004 09:03 PM
