Incorporating reserve battery for computer when disconnecting main battery
2000 F250, 4x4, CCSB, automatic, V10. Electrical gremlins are driving me insane. Mainly after it rains a considerable amount. If I don't disco the battery it has to be jumped, overnight to go to work, end of the day to go home. New battery and alt. I assume the disco isn't great for the computer with doing it twice daily? Considering a remote disco so I don't have to pop the hood every time. I'm guessing a backup battery for the computer would be a good thing. What's the proper way to wire said backup battery?
If the main battery or batteries are being drained, then the aux battery you add is going to be drained also. Easiest would be to plug the truck onto a charger when it sits. You will have to park it near a 120v receptacle, but you can mount a small battery maintainer that you can buy at Walmart in the engine compartment somewhere and hook it to the battery, and have the cord coming out of the grille like a diesel. Just plug it in when you park it.
If you go to work and leave it sit 8-10 hours and it won't start then, then you have a serious problem that needs addressed. Have you ever put it on a charger? I am wondering if the battery is fully charged when you leave the house, how long will it last before it needs charged again?
We haven't had one of these in awhile, but your post brought back my memory when reading your symptoms. Your truck is new enough to have some fancy features to it, but old enough to where these features are not integrated with a bunch of smart fuse boxes and body modules. Your truck has what they called the "GEM" module. It's a box with a circuit board in it that has all the automated features of the truck inside it.
The GEM module works fine until it gets wet. Your generation of truck had a terrible time with the windshield leaking. These leaks would run down the inside of the firewall and guess where the GEM module is mounted? Yep, inside the vertical firewall on the driver's side. Also your main fuse box is near there, so it can get water in it too, and corrosion can set in.
I would pull the carpet back on the driver's side, and see if water has been leaking down over there. You can also check it after a rain and see if it's wet. If it is, hopefully there is not too much damage. To repair it, you simply take the truck to a glass shop and have them re seal the windshield. It would be wise to pull the GEM and also check the fuse box to see if there is some impending event that is going to happen from corrosion and bad connections.
Ken Blythen
Dec 17, 2008 02:49 PM
stevo410
2004 - 2008 F150
May 30, 2006 10:37 AM
