No the dealer did not tell me anything, surprise surprise. No, the manual says nothing about detecting an auto regen event or what to do while it is happening. I looked in the manual before I ask the question. Again no surprise about manual saying nothing. I hoped it would just be a simple question with a maybe simple answer. Thanks.
But isn’t the point that people are skirting around is if you turn off the truck while it is in a regen you are not going to blow the truck up.
, it wont blow up the truck, it just doesn't complete a full regen cycle and if the cycle had just started, then it will restart once temps reach a set point, but will take longer and use more fuel.
This ^^^
And two ways to tell without any third party options from the dash (Sound, smell, etc are other things too).
DPF% will drop very fast - less than 10 minutes.
Your MPG real time meter with average as a digit will drop drastically so even cruising on level terrain at 65-70 it will be in the low teens/single digits on that gauge for those 10 minutes, it will immediately return to normal as soon as its done.
When it hits 0%, I'll drive for 3 to 5 minutes after that if needed, but so far the trips are in my favor that it never happens close to ending a trip, just within 5 mile of stopping it ends.
I fill up when the gauge hits between 1/3 and 1/4 of a tank, seems to work out pretty well for getting a regen every fill up.
I've never paid a moment's notice to regen. Never altered driving behavior, kept it running after it reaches destination, or bought a monitor to track when it is about to happen. It is an automatic system that I let do its thing.
