Troubleshooting hard start
So the first thing first. I replaced the fuel line between the Facet pump and the filter with a piece of clear tube, primed the system, ran the engine for a few minutes and let it sit overnight. Popped up the hood next morning and I saw this:
Pulled fuel filter and sure enough, it was half empty. I have independent switch for the pump so I can run it with key off. Ran the pump for a couple of minutes and went to cranking. Won't fire, outside is about 40F. Then I thought well, with key off my fuel shut off solenoid is probably blocking the path to the IP and it still could be empty. Turned the key on, ran the pump for a while, got in the truck, cycled the key off/on to get the glow plugs on and she fired right up.
So yes, air intrusion, but where? I was still confident about fuel return lines, caps and o-rings so started looking around. Fuel filter housing and the bracket have been covered with fuel which I have seen before, but ignored it. First thing I found was air bubbles coming from under the schrader valve cover while engine was running. Replaced it, cleaned everything around and kept looking. Pulled the plug off the fuel restriction sensor, or whatever it is, to clean it up and found air bubbles coming out of it. This was getting interesting, so I started the engine and was looking at that thing. What I saw was fuel coming out of it and dripping at the rate at about 1 drop per second.
Pulled the thing out, cleaned with compressed air and put it back in. I wanted at that time to replace the fuel return line which goes from filter to #1 injector with a piece of clear one, but didn't have any of 1/4" tubing on hand. This is a small leak that I don't believe would be my main problem, but who knows. And now I started to lose my confidence in fuel return kit I have installed earlier. Had to go about another business and let the whole thing sit until next morning which was today.
Same 40F this morning. Ran the pump for 5 min with key on, cycled key off/on, waited until "wait to start" light goes off, cranked it over and she fired right up.
Have I screwed up the installation of Pensacola kit? Not likely, but who knows, so I am ordering new sensor and a new Delphi fuel return kit tonight. Will post more after I am done with it.
what ford found was the one way valve in the filter head the line from the injector goes to is not as good as it is supposed to be. it had been disconnected on my 88 for around 425,000 miles with no issues at all.
when i first did it, i took the line off the filter head and put a bolt in the line with a hose clamp to keep it tight. then removed the valve and put a brass line cap in its place. when i needed a return line kit around 100,000 miles later i just used a single outlet cap on #1 injector.
I didn't remove return line from fuel filter head to #1 injector as Tom suggested but replaced it with a piece of clear tubing instead and replaced leaking fuel restriction sensor.
After sitting overnight there was air in supply line and return line was empty. Ran e-pump for a while and got it running. With engine running was observing the return line. I saw fuel flowing but it still stayed empty. Drove the truck about 3 miles, stopped to check return line and it still wasn't full. After another 5 miles or so around the neighborhood it finally got full.
Since I found a faulty FSV on my other truck I thought that I may have a problem here too. I've been using the truck with single tank for 5 years and didn't feel like I need the second tank, so I pulled FSV, cut back rusty portions of steel fuel lines and ran 1/4" hoses straight to the tank.
Primed, bled the injectors, got her running and noticed some difference.
1. Return fuel line got filled before even engine warmed up.
2. This was the most interesting. I was complaining a while back here that my engine sounds like a tin can full of loose bolts and nuts which kept bothering me especially that I have another truck right here which runs nice and quiet. So, to my big surprise, there was no more of that nasty clanking noise. It was running as diesel supposed to and was quiet to the point that I heard my exhaust standing in front of truck with hood open.
Shut it off and let sitting until this morning. It was around 30*. Again, air in the supply line and empty return line. Primed, cranked and she fired up on the first try which never happened before at 30* without plugging block heater.
Well, air intrusion still there. Shut the engine off and noticed that air showed up right away in the supply line.
Now I am puzzled. Filter is tight, leaking schrader valve replaced, leaking fuel restriction sensor replaced, no leaks around fuel heater connector, no air in return line, checked tank vent and it's good. The only thing remaining is supply line from filter head to IP and the fitting on filter head is slightly wet. So what do you think guys? Where this much of air is getting from into supply line right after engine shuts off?
I jb welded in this one, because they said since it wasn't brass, it could turn out. I used a brass one in the other truck, after. I can attest, both methods work.
I didn't know there is a check valve on return orifice, so now it's clear enough that air is getting from somewhere on the filter head, not from return system. I read that people replace that steel fuel line to IP with flexible hose and there are kits available somewhere. Does it make sense to bother and what's in the kit?
I will look into fuel heater later in greater details. Got to run now.
I just popped up the hood and see that there is still the same amount of air in the supply line as it was yesterday.
So I played a little more today. Shut off the engine and left e-pump running, then shut off the pump. Air immediately showed up at the top of the supply line at the filter head. Pulled the filter and it was about 1/4" from being full. That is a pretty good deal of air in a split second. Isn't it because of no more pressure applied by the e-pump? It's impossible that any small leak in the filter head will allow this much air right away. And return line from filter head to #1 injector is full of fuel with no signs of air, so check valve is good.
Then I wanted to see what's going on with this on the other truck. Shut off the engine, shut off the pump and got air the same way. However, about half as much. It was going dark already, so I didn't pull the filter there.
So the big question is: Maybe it's normal? Both trucks share the same setup with Facet pumps and lift pumps removed. The other truck starts right up even with old batteries which won't turn starter at all after 10 sec of cranking.
BTW Is it worth paying $140 for this: High Performance Ford or Chevrolet Moose Fuel Feed Line $140.00 – Moose Diesel LLC
Shame on me not putting the part #'s in my records. In fact, I missed putting the upgrade was done at all in them. I'll have to figure it out now or it will bug me haha.
OK Maybe:
Parker 75826; Swivel Elbow Fitting 90 Degree; 1/2NPT
Looks just like that. It's the swivel style so you can get it down in there and snug it up while keeping it straight up. Searching on here, they're saying (here) the rear thread is 1/2 NPT so I guess that must be that.
The 1/2npt to barb should be easy now......
Well any of them work I guess, but I got the "push on" style where you don't even need a hose clamp, though I use one anyway.
Hose Barb to NPT Female (Brass) 1/2" Push-on Barbe to 3/8" - Is this right? Did I use 3/8 hose here? ....Think so.
So maybe like like one;
Push-On Hose Fitting: Hose Barb x NPTF, 1/2 in x 3/8 in Fitting Size, Male x Female, Rigid, Straight - PB-NPF-0806
I wasn't picky about my hose barb style haha. It's just they had those on hand is all. 1/2 npt female to hose barb anyway.
I'll look to see what I did for sure to hose size and add these to my records if this is right.
Then some hose and Bobs your uncle. Oh, then of course whatever it took to screw on a hose barb up on the filter too right. I almost think I found them at the hardware store.
So anyway, there ya go. You can see about finding those and the cost. No doubt much more affordable, for two trucks even. Plus the other two fittings at filter head and some fuel hose to find total cost. Doesn't look pretty but matches the rest of the engine.
Doesn't stand out. I'll try and grab a photo of it on one the trucks tomorrow.
I'll do some more experiments but need a nice day or two as it's cold right now. I can cut trees or move dirt in this weather but rather don't play with the truck unless it's something urgent. Since I ditched my FSV she fires up pretty good in the morning after priming for a few minutes, so no rush.
Just came across this check valve and wonder if anybody used something like this: Aluminum Fuel Anti-Drainback Valve for Sale | Accurate Diesel
^ There you can see, just a run of the mill 90 degree fitting, whatever the thread size is, to hose barb. Looking at it, I'm not so sure it's correct either. I have 3/8 fuel hose on there and I think that might be a 5/16 hose barb haha, well if so, neither truck is leaking. I think I better inspect this, if this is the case, I'll change those. Seeing this in photos makes me wonder. Could just be an illusion. I have more of this 3/8 fuel hose in the garage and I see it's kinda flat looking.
There's that jb-welded galvanized pipe plug, in the heater port, 10 or so years latter. Dry as a bone. Though I did use a brass plug on the F250, after plugging this one off.
Install hose onto IP, fill line with Fuel, ATF, or?? to eliminate air in the line.
then connect to Filter.
https://russrepair.com/filter-to-ip-...ne-delete-kit/
If you use Push lock Hose, do not use a clamp.
Like Tom mentioned, eliminate the line from Filter to #1 Injector. Did mine several years ago,
never had a problem doing away with it.
There was a TSB (Technical Service Bulletin) from Ford quite a few years ago to eliminate
it as it was causing a problem.
You could have air intrusion at the Lift Pump, or the curly Q hose going to it. Might be old and
cracked at the Clamps. Noticed my LP was wet on the bottom, and replaced it before it caused
problems.
Dont go buying another Injector return line kit thinking the new one is bad.
You can buy bags of 50 from McMaster-Car for around $10, size 111, Viton.
I reuse my old caps, and have a container of used caps. Got a bunch from PNP
off engines that had them recently replaced.
Charlie
