Sponsored by: Innova
CB probs
Old Dec 2, 2003 | 10:12 PM
  #31
pfogle's Avatar
pfogle
The original antenna I had was a radio shack 54" magnet mount 5/8 wave ham/cb antenna It was nice, but I forgot to take it off of the car one night and it got froze. Ruined the load coils in it.
Old Dec 2, 2003 | 10:13 PM
  #32
Peter94's Avatar
Peter94
hey, rebel, where do you have your whips mounted? on the inside of your bed? my big problem is that i have an access roll up tonneau cover, unless you can clamp it on between the bed and the cab somehow, i cant really find a way to put some whips on, which i really want
Old Dec 2, 2003 | 10:21 PM
  #33
rebel_ford4x4's Avatar
rebel_ford4x4
mine are bolted to the front of my toolbox actually. the whips came with mirror mounts so i just took the front half of the mount and bolted it to my toolbox. i would have just mounted them to the bed but i couldnt fit them in there with the toolbox and i didnt wanna get rid of it. probably the only way for you to mount yours is to the bed, but make sure its on the highest part of the bed so that way you get higher above the cab.
theres no close up view but you can kinda get an idea of my setup by lookin at the pics in my gallery.
Old Dec 2, 2003 | 10:30 PM
  #34
Peter94's Avatar
Peter94
Yeah, i need some ideas on where to mount some if i get them, cause the tonneau covers up the bed, but the side rails and the stake pockets are open, so maybe somehow there, but i guess i'll have to brainstorm on it
Old Dec 2, 2003 | 10:31 PM
  #35
rebel_ford4x4
the stake holes are an option i went with. but once again my toolbox blocked the front ones.
Old Dec 2, 2003 | 10:32 PM
  #36
Andysutt's Avatar
Andysutt
I've seen them mounted in stake pockets... not sure how but I seen them once.
Old Dec 3, 2003 | 02:41 AM
  #37
ZombieSlayer's Avatar
ZombieSlayer
Peter,
Using mirror mount brackets you can mount your whips on the cab just above the bed. You'd have to drill holes in the cab, but they'd be covered and you could seal them from the inside.
You could mount them even higher at each end of the window.
Just a thought.
Old Dec 11, 2003 | 08:05 PM
  #38
blahblah's Avatar
blahblah
You would be better off using the stake holes if you can. Firestik and others make a stake hole mount. With it, you can mount your antenna either on the inside or outside of the bed.
