Sponsored by: Innova
CB probs
Old Dec 1, 2003 | 02:21 PM
Jimmy Dean's Avatar
Jimmy Dean
CB probs
Ok, some of you know I put a CB in my truck......now I cannot transmit and recieving is real weak. or at least If I can transmit I cannot copy when anyone replies back, it was working just fine on thursday on my trip down, was working great, and that was in the rain the whole trip, transmissions clear as day for about a mile....started to fade after that (remember I havae a crappy antenna right now)
I cannot visibly SEE anything wrong, is it possible my cheapo antenna just...crapped..out on me?
Old Dec 1, 2003 | 02:33 PM
jrs_big_ford_f150's Avatar
jrs_big_ford_f150
I think the cable between your antenna and your radio is water contaminated causing a short. Your best bet is to replace your antenna cable.
edit : I would consider replacing the antenna also.
Old Dec 1, 2003 | 03:11 PM
rebel_ford4x4's Avatar
rebel_ford4x4
what jr said is probably true. otherwise make sure all your connections are good, and the fact you say "cheapo" antenna might be the case too. what kind of antenna is it?
Old Dec 1, 2003 | 03:29 PM
TheWiz427's Avatar
TheWiz427
Check your SWR's!
Old Dec 1, 2003 | 03:33 PM
Andysutt's Avatar
Andysutt
I agree with TheWiz there.. check your SWRs
90% of people Id say never even check them, they just throw them in the truck
I made my CB talk a lot further and sound a ton better by setting my SWRs
Old Dec 1, 2003 | 03:35 PM
theologian's Avatar
theologian
Andy, that signature is WAY TOO BIG, you will show the rest of us up..
Theo
Old Dec 1, 2003 | 03:37 PM
Andysutt's Avatar
Andysutt
Um... wait ya confused me :P send me an email or something. lol
Really tho, if its a problem, I can change it, but I spent all day on it
Old Dec 1, 2003 | 04:21 PM
theologian's Avatar
theologian
NOT at all, Andy,,, send me an email with the code in it,,,, PLEASE
Theo
Old Dec 1, 2003 | 04:22 PM
Andysutt's Avatar
Andysutt
I'll send it to you, but you'll have to get rit of some of your other signature. I had to shorten mine up quite a bit
Old Dec 1, 2003 | 04:24 PM
theologian's Avatar
theologian
Time I changed my sig anyway.. I shouldn't have the 250 on there, it is Sarah's, and the 150 is in bits.. with no seats....
Along with other junk sitting waiting.
Theo
Old Dec 1, 2003 | 05:22 PM
pfogle's Avatar
pfogle
When you set your SWR make sure it's ~1:1 anything higher than 1:1.5 can blow the finals in the radio.
Old Dec 1, 2003 | 05:25 PM
Texan1983's Avatar
Texan1983
umm... i am thinking about getting a CB for emergencys. but don't know the first thing about them. what are SWR 'S?
Old Dec 1, 2003 | 05:55 PM
Opiewan's Avatar
Opiewan
standing wave ratio
swr
go to a cb shop they can check them and they usually do it for free or just a couple bucks, also make sure you have 14 feet of coax for you attenta. i like the francis fibergalss attentas, they are cheap about 14 bucks for a 6 footer but they work really well, i have had them on all my semis the last 9 years.
oh and if you got the extra cash have your radio tuned and peaked, no need to go for the big echo box or the mod kit just get a good tune and peak. that gets you receive and transmit all dialed in. and make sure you attenta is grounded well, makes all the difference in the world believe me. good luck and see you on the road sometime, my handle is LUCKY 2
Old Dec 1, 2003 | 05:57 PM
Andysutt's Avatar
Andysutt
K-40s If im not mistaken are good antennaes, I ran one for a long time
Old Dec 1, 2003 | 05:59 PM
pfogle's Avatar
pfogle
When you buy your CB (most high end ones have the "calibration" mode built in) If not buy a SWR meter. It tells you the "Standing Wave Ratio" there is a 2 position switch (don;t have one in front of me and been a long time since I did) on the one setting it should not come off of the left peg, on the other setting it should be above 1.5. (1:1.5 or less) for best range. Don't skimp on the antenna either, and don't go for the biggest just because it looks cool either, talk to a CB shop and get the one that will work the best for your application.
