2024 7way plug question
Old Nov 14, 2024 | 03:39 PM
ownbeya's Avatar
ownbeya
1st Gear
Good evening, I just purchased a 2024 f250 7.3. I pull an enclosed trailer everyday. I have lights on the inside of the trailer with a switch to turn on and off. My Chevy (previous truck) the hot wire on the 7way plug was hot all the time. On this truck it’s only hot when you plug it for the first time. Once you turn the truck off and then drive it again the power is gone.
does anyone know how to fixed this?
I am new to the ford world so any advice would be greatly appreciated.
Old Nov 14, 2024 | 06:36 PM
RbrtLls's Avatar
RbrtLls
While I am not an expert, I believe that a Ford disconnects the 12v hot to that wire when you are not towing. That is to prevent a travel trailer from drawing the truck battery down when parked.
I may be wrong though.
Old Nov 14, 2024 | 10:05 PM
poopy_pants's Avatar
poopy_pants
There should be power on that as long as the truck is running. I've used it for powering an 12V cooler in the bed multiple times with a 7-pin to accessory plug like this.
POLLAK 11-896 7-Way Power Outlet Adapter POLLAK 11-896 7-Way Power Outlet Adapter
So if this works, your trailer certainly should.
Old Nov 15, 2024 | 08:39 AM
5picker's Avatar
5picker
Something isn't right. While Ford doesn't leave the 12v connection in the 7 pin hot all the time, it should be hot once you restart the truck.
Old Nov 15, 2024 | 06:11 PM
Jerry Weigel's Avatar
Jerry Weigel
I bet upon restart and the lights no working after trucks is started and running, upon unluging the 7way and plugging it back in again, the lights (12V acc power) will again work. There is a TSB and a thread on here talking about it. The thread started said it solved his issues I had the TSB performed and it did not solve mine. I need 12v ACC power for the air ride trailer suspenstion and hydraulic disk brake pump. May just run one of the upfitters back and tap into the 12V ACC power wire so I can manually add power (upfitter turned on).
jjw
ND
Old Nov 16, 2024 | 06:12 AM
JohnD333's Avatar
JohnD333
I believe that after initial connection the trailer battery charge circuit in only active with the driver’s door closed. This may be to prevent truck’s alternator or Battery Monitoring System from freaking out.
irly
6.7L Power Stroke Diesel
Aug 8, 2022 01:57 PM
murraycookies
Nov 17, 2017 04:10 PM
shaffecv
May 21, 2017 09:36 AM
River
2009 - 2014 F150
17
Dec 20, 2015 09:33 PM
Spirit615
Oct 8, 2007 01:15 PM
