Ride Height?
Old Nov 6, 2024 | 09:33 PM
ag-ford-4x4's Avatar
ag-ford-4x4
Ride Height?
I feel like I missed the best looking redesigns in the 2019 trucks, but it also seems like the new trucks have lower rear ends? When did ford make this change? When did they take that sweet stance and make the truck look like it's dragging ***? I need a new truck, but want to know what years to focus on. Does anyone know?
Old Nov 7, 2024 | 06:19 AM
406f150's Avatar
406f150
They got the lower ride heights with the 2020 refresh. Depending on model 1-1.5" lower in the rear and 1/2" lower up front.
Old Nov 7, 2024 | 06:36 AM
Tsax6010's Avatar
Tsax6010
I would call it "back to reality". HD trucks were getting out of control tall, causing all kinds of issues getting 5th wheels to tow level. I appreciate the ride height as-is on my 24 450.
Old Nov 7, 2024 | 06:49 AM
Poncho450's Avatar
Poncho450
It's all a personal preference but I'm not a fan of lowering or leveling. For my uses I like a bit of rake. Then if I get a load it will level out the look and not have the headlights point upward.
Old Nov 7, 2024 | 07:55 AM
willynilly's Avatar
willynilly
most people want the dragging *** look. so thats why the trucks are that way
Old Nov 7, 2024 | 09:49 AM
acadianbob's Avatar
acadianbob
It is a practical reason to make the trucks lower from the factory. So you reach into the bed. So you can lift things into the bed. So that you can pull your fifth wheel without the nose of the trailer pointing at the sun. If your truck is a fashion statement, you can always raise it your self.
Old Nov 7, 2024 | 01:07 PM
DPelletier's Avatar
DPelletier
The 2020+ trucks are lower than previous (which is a good thing functionally as pointed out by others) but they maintain their rake (which is also a good thing functionally if you actually use your truck to tow/haul stuff). I don't like leveling kits either.
If you want the highest factory height, stick with a 2019.
2 cents,
Dave
Old Nov 7, 2024 | 01:08 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
My '24 has less rake and weaker/softer springs (or much different spring rates) than my 2018 had. The same trailer with the same load makes my '24 squat with negative rake. My 2018 sat level or still 1/2-3/4" high in the rear.
I would like to see lower bedrails (depth of the bed). The bedrail height is 3+ inches taller than an OBS truck from the bed floor. Lifting a full 5-gal gas can over the side sucks...
Old Nov 7, 2024 | 07:03 PM
coolidge54's Avatar
coolidge54
They got lower? My brother parked his Ram 3500 next to mine today, my 2024 F250 Tremor made his truck look small.
Old Nov 7, 2024 | 07:58 PM
ag-ford-4x4
What a bummer. Why the hell did they do that? These new trucks look like ***. They sit level or like they had a 16 year old take it to a hack shop for suspension work. Color options are boring as hell. Man, I'm gonna have to go back to 2016-2019 I guess. That's fine, but tough to find one with a warranty.
Old Nov 7, 2024 | 08:14 PM
Rwhjr's Avatar
Rwhjr
quit crying just get a ****in 3.5” rear block and be done with it. That’s the only change they really made anyways was a smaller block.
Can probably get a set of takeoffs and new u-bolts for next to nothing and they can be swapped with minimal tools and an hour of your time. And voila you have the same as any previous alumiduty since 2017
if I recall the fronts are really only an inch lower. If desired get a small spacer and toss that in with some caster shims and you’re good.
But as others said it was done supposedly for functional reasons.
1966F100SC
22
Apr 8, 2021 10:00 PM
papabills54
Sep 15, 2017 08:24 PM
riverratba
2009 - 2014 F150
16
Jan 6, 2015 03:18 PM
cricket
Jun 1, 2001 11:39 PM
akexpy
Oct 12, 2000 09:16 PM
