Sponsored by: Real Truck
Engine Replacement
Old Nov 5, 2024 | 09:37 PM
Pablopiedra's Avatar
Pablopiedra
2nd Gear
Engine Replacement
Hi All, I’m a noobie here and have searched the threads for a couple days before posting. My apologies if this has been discussed already, I wasn’t able to find much.
I have a 2004 F350; 5.4l v8, manual transmission, 200k miles
I’d like to size up the motor but struggling to learn of easy-ish options. Ive replaced motors, so familiar with the process. I use the truck for snowmobiling and tired of climbing hills in 2nd gear. Is there a relatively simple swap to something with more power? Current engine runs ok, has a bunch of deferred maintenance and a leaking head gasket (plus frustrated with the lack of power), so the repair costs may be lead to a replacement regardless.
Anyone know of some options?
I figure anything is possible, just looking for a simple option. Appreciate any direction.
Paul
Old Nov 5, 2024 | 10:33 PM
Ted722's Avatar
Ted722
Best way to search is using a search engine on the web.
Your'e looking at a wiring harness, possibly an entire transmission (maybe can just put V10 clutch kit in), motor mounts, and more. A lot of threads on this, but I've had the 5.4('99 Expedition) and now that I've got the V10 (F250) i'd say it's truly an upgrade worth researching/pursuing. Especially with your manual transmission.
Example search of 5.4 to 6.8(V10) swaps:
https://www.google.com/search?q=5.4+...t=gws-wiz-serp
Old Nov 6, 2024 | 07:04 PM
Pablopiedra
2nd Gear
Thank you Ted, Google is helpful… go figure.
Old Nov 13, 2024 | 01:38 AM
Oz52F1's Avatar
Oz52F1
7.3 Godzilla with aftermarket ECU.
Look at my build threads for the painful way............
Nashcat
1997 - 2003 F150
Feb 20, 2024 10:04 PM
alxsnmr
Sep 28, 2022 04:27 PM
Keepin-it-simple
Jan 29, 2011 03:50 AM
Cruiseomatic
General Automotive Discussion
May 24, 2008 09:00 AM
