Sponsored by: Real Truck
Ac hose question
Old Nov 13, 2024 | 07:13 AM
Kendot21's Avatar
Kendot21
7th Gear
Ac hose question
So far I've been unable to confirm this. My local dealer was unable to help, either.
On the suction line ac hose there is an integrated "canister" that appears to likely be a built in filter dryer. Can any of you confirm it as such, or, does it serve as an accumulator to prevent liquid refrigerant from slugging the compressor?
Addendum: I have finally found the answer. The item in question, supposedly is a "muffler" used to quiet the ac, or so a person at a local Ford dealer told me. I am replacing this ac line so I will do an autopsy on the old line to confirm the claim.
The section of the hose in question is obviously an accumulator type device that allows liquid refrigerant to convert to vapor before entering the compressor. It is nothing but a hollow compartment (I opened it to see) and those are nothing more than an expansion chamber that briefly lowers refrigerant pressure as it expands within the chamber thus allowing it to transition to vapor.
Photocow
Jul 31, 2024 07:57 PM
rodney961
Apr 29, 2013 01:57 AM
77kalt
Jul 8, 2011 09:53 PM
