302 won't start when warm
Old Dec 10, 2003 | 07:02 PM
  #61
Tim Ervin's Avatar
Tim Ervin
I've seen diagrams of the switch posted here before from some manual. If I have time later, I'll try searching for one that was good. There are several posts concerning ignition switches that could give you more insight. Do you have a manual?
Old Dec 11, 2003 | 06:52 AM
  #62
tulsaokjoel's Avatar
tulsaokjoel
I've got the Haynes manual. It has continuity tests for the switch in there. I don't remember what it has about getting to the switch though.
Old Jan 5, 2004 | 06:03 PM
  #63
alleyshadit's Avatar
alleyshadit
Well, this is actually alleys hubbycartool because I do the physical work.
First, we have the exact same problem, but we know when and how it began.
On the hottest day in July, when the temperature went over 100, the battery isolator
kicked in and shut off all of the electrical power, everything. That's when we began
replacing the batteries and alternator. The battery isolator is a custom part, but the
fuse protecting the whole accessory harness is not. Once replaced, the van restarted,
but after warming up would stall at stop signs or while parking, and then give painstrying to restart.
The whole process, thus far, has led us to some part of the ICM or ECA, and nothing
whatsoever to do with the fuel pumps, etc. This problem is a Ford problem!
We suspect it to be an electronic component that is failing when hot.
Will get back. By the way, I like the line of reasoning that says a no start is being
caused by something and reset when the pump or spout is disconnected.
alleyshadit
Old Nov 5, 2004 | 06:13 PM
  #64
87f150xlt's Avatar
87f150xlt
was this problem ever resolved? I have a 87 F150 that has identical problem, no problem starting at cold but doesn't fire up when warm. I believe it's something to do with electrical. any help or info appreciated.
Old Nov 6, 2004 | 06:30 PM
  #65
87f150xlt's Avatar
87f150xlt
I now have a new ignition switch on the truck but the problem didn't go away. I had to disconnect Inline fuel pump or disconnect Inertia switch behind fuse block to start the truck when warm. I installed a toggle switch on the Inertia switch line to make warm start process better but weirdest thing is I don't have a problem starting the truck after installed the switch even when warm. Like to get to the bottom of this problem sometimes.
Old Nov 6, 2004 | 07:01 PM
  #66
87f150xlt's Avatar
87f150xlt
BTW, Ignition switch I got is updated version compare to original on 87-91 F series/Bronco. Motorcraft SW-2472 or F2TZ-11572-E, I got this switch for $13.28 list price at Burd Ford in Indianapolis earlier today. Advanced auto parts wanted almost $12 for aftermarket switch. Asking for replacement Ignition switch at the dealer will get you the original old design SW-2929?(I forgot) List price $16.60. Get SW-2472 from the dealer, it's improved version of the original and would last much longer than original and cost less.
Old Nov 8, 2004 | 09:00 AM
  #67
87f150xlt's Avatar
87f150xlt
I had the won't start when warm problem again last night. fuel pump kill switch I installed became very handy. Like to resolve this problem sometime.
Old Nov 8, 2004 | 10:55 AM
  #68
stepman's Avatar
stepman
O.K. guys, try this if you haven't found a fix yet. Next time it doesn't start, put the gas pedal to the floor and try it. You may have to let it crank for 15 or 20 seconds. If it fires, do you see a lot of black smoke coming out the tailpipe? I'm still thinking a bad temp sender ( after reading thru this whole thing again)
Old Nov 8, 2004 | 01:35 PM
  #69
87f150xlt's Avatar
87f150xlt
Stepman, I will give that a try next time. hopefully today but if not within couple of days as I don't drive this truck everyday. Where is Temp sender located? I got 302 EFI also. is it one of those located on intake near distributor? is it analog or just on/off switch? if it's just on/off switch I can check the stage it's in next time it happens.
Old Nov 9, 2004 | 06:53 PM
  #70
87f150xlt's Avatar
87f150xlt
I found Temp switch as follows; from autozone.com
On your 1987 FORD TRUCK F150 1/2 TON P/U 2WD, the TEMPERATURE SWITCH is:
UNDER HOOD, DRIVER SIDE, UPPER ENGINE AREA, REAR OF DISTRIBUTOR, NEXT TO VALVE COVER, MOUNTED ON INTAKE MANIFOLD
is this the temp sending unit you were talking about?
Old Nov 9, 2004 | 08:47 PM
  #71
stepman's Avatar
stepman
That one may be for gauge. I think there should be one near the thermostat also. It will be variable so that it can "read" different temps. It may read 50 degrees when cold which would be O.K. but, if it still reads 50 degrees when hot it will think you need to "choke it" adding too much fuel.
Old Nov 10, 2004 | 09:45 AM
  #72
87f150xlt's Avatar
87f150xlt
Coolant temp sensor
There is a Coolant temp sensor near the temp switch also, it's sensor and reads temp for the gauge. I know this sensor works because my temp gauge works. the temp switch on the other hand it's either on or off, for cold start and such.
Old Nov 11, 2004 | 11:31 PM
  #73
87f150xlt's Avatar
87f150xlt
Stepman, I got to try pedal to the floor a while ago. after catching couple of times engine fired up in less than 10 secs. no smoke came out. I never tried the pedal before since the truck is fuel injected. also, when I first started the truck it didn't go in to cold start(high rpm)mode like it usually does, but when in that mode after I pedaled it couple of times.
redbayredneck
18
Feb 27, 2017 09:01 PM
bl1989
Jul 7, 2016 03:02 AM
lvin4jc
Nov 12, 2015 04:14 PM
72F250390
16
Jul 15, 2005 05:20 AM
wtf
Oct 9, 2001 02:23 PM
