Sponsored by: Real Truck
a/t control solenoid question
Old Nov 4, 2024 | 11:42 AM
tommyl's Avatar
tommyl
2003 f2502wd 7.3; 220k miles. It is throwing code p0783 when towing (only) down shifting from OD to D. Bought truck used, Filter and fluid may never been changed.
Contemplating changing the control module. So the question; I see the module listed with or without PWM. I don"t know which one that I need. Help, Thanks
Old Nov 4, 2024 | 02:22 PM
Jimmy's Pilot Service's Avatar
Veteran: Navy
May need a full fluid exchange with new filter... This will take about 22 or so quarts, or 5.5 gallons if your brain likes that number better.
May be the Valve Body.
May consider the above two at the same time as the bottom will be open.
May be the harness..... emphasis on may on this one.
Old Nov 5, 2024 | 08:04 AM
tommyl's Avatar
tommyl
Old Nov 5, 2024 | 02:21 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
For that code it almost certainly isn't the solenoids. But if you want to replace them you need the one with the PWM.
Old Nov 6, 2024 | 10:21 AM
tommyl's Avatar
tommyl
Thanks Mark!
big315
Dec 9, 2018 04:49 PM
sjprice
6.7L Power Stroke Diesel
Apr 14, 2010 02:43 PM
edf250
Feb 14, 2010 05:27 PM
Ted Wolf
1997 - 2003 F150
Aug 22, 2005 09:22 PM
tmcalavy
Apr 13, 2000 12:08 PM
