460 timing issues
Old Oct 29, 2024 | 07:50 PM
94obs's Avatar
94obs
460 timing issues
Hey guys!
figured I would post here before I screw something up. I’m a 20 year old kid doing quite a bit of work to my 94 460.
I replaced intake gaskets, rebuilt injectors, new timing chain and cover. Water pump, and new vacuum lines and all new belts.
The whole thing took me about a month and a half.
finally got it back I together, and it runs pretty terrible. I haven’t ran it more than a couple seconds at a time because I’m scared something will break.
when I re-installed the distributor, I put the harmonic balancer to 10 degrees btdc on the compression stroke. And reinstalled my distributor how it was to match the marks I had made before taking it apart.
does Anyone have any idea why my truck would run so bad? And any tips on what to do or where to start? Kinda new to this whole thing.
I am going to attach a video of the way it’s running. Hopefully will help you give me a starting point. Also, the truck starts right up. Is there anything else that could cause this?
File Type: mov
Old Oct 29, 2024 | 09:44 PM
My4Fordtrucks's Avatar
My4Fordtrucks
I’ve never heard of placing the crankshaft at 10° BTDC and then installing the distributor. How do you know that the mark you made is still any good? There won’t be any slop in the new chain. When you installed the timing chain everything was set at 0°? That is when I would install the distributor with the rotor pointing at # 1 terminal. Once the engine was warmed up I would use a timing light to adjust the distributor (after removing the spout) to 10-12° BTDC
Old Oct 30, 2024 | 11:54 AM
wwhite's Avatar
wwhite
Such a short video/sound clip, actually doesn't sound that bad to me.
Maybe an exhaust leak, or lack of oil getting to the rockers.
How did it sound before you did the work?
Old Oct 31, 2024 | 03:19 AM
94obs's Avatar
94obs
The truck ran like a top before.
let me set it back to 0 degrees and we’ll shoot it with a timing light
thanks guys
Old Oct 31, 2024 | 03:31 AM
94obs's Avatar
94obs
Yes,
when I installed the timing chain everything was set at 0degrees. I will set the crank back to 0 and have the distributor pointing at #1 terminal.
thanks
Innov8tive1
62
Apr 25, 2023 10:05 AM
Driverjoe92
Feb 11, 2022 07:09 AM
fordtrucks99
25
Sep 4, 2017 12:00 PM
EvoDawg
Jan 25, 2011 10:06 AM
fyrfytr
May 16, 2002 03:05 AM
