Towing
Old Oct 28, 2024 | 02:04 PM
preacherman39's Avatar
preacherman39
1st Gear
Towing
I am new to diesels and need help with towing.
i have an SCT tuner. I used tow 50 for my first 300 mile trip pulling a fifth wheel which is heavy!
I towed a while without it and couldn’t really tell much difference in power, etc.
it is a 2006, 6.0 F-350 crew cab.
i had to keep my foot in it most of the time and I know it will be a strain in the mountains.
I’m not sure which tune to try.
any help will be much appreciated…
Old Oct 28, 2024 | 04:40 PM
'89F2urd's Avatar
'89F2urd
The problem is, the higher tunes are hard on the transmission while towing. You could try a higher setting, just be mindful of unnecessary pedal. The 6.0, even tuned, still needs to rev to make power so it may seem like it's a turd until you let it downshift.
May be a stupid question, but did you try the tow/haul mode?
Old Oct 28, 2024 | 05:00 PM
joe blow's Avatar
joe blow
The most important question is your truck rid of all the achilles heels?
ARP studs installed
Aftermarket egr cooler (if not deleted)
I suggest you have custom tow tunes written or you will most likely have issues, if you don't already.
The canned tunes (if applicable) are garbage IMO.
Old Oct 28, 2024 | 05:20 PM
JJF20's Avatar
JJF20
Welcome to FTE,
Before you go to far into tuning, I’d suggest sitting down and reading up on the 6.0 and how to monitor it, especially towing heavy in mountains.
Here’s a few threads to get you started..
https://www.ford-trucks.com/forums/7...-problems.html
https://www.ford-trucks.com/forums/7...ew-owners.html
https://www.ford-trucks.com/forums/9...used-6-0l.html
https://www.ford-trucks.com/forums/3...ch-folder.html
Old Oct 28, 2024 | 05:59 PM
runthatjunk's Avatar
runthatjunk
I know it will be covered in the links above, but if your absolutely new to this platform you need to check the oil cooler deltas immediately.
wabassguy1
Aug 14, 2015 07:41 AM
florida_1959
Feb 21, 2012 06:55 PM
8e3k0
6.4L Power Stroke Diesel
Jul 22, 2009 08:44 PM
Technocrsr
27
Apr 20, 2009 07:05 PM
Motossanch
All Things Towing
Sep 7, 2007 06:24 AM
