They are a ACdelco rapid fire platinum, just the cheapest ones the local parts store had. I will look into some other plugs. Any good brand recommendations?
ALWAYS use Motorcraft plugs in a Ford
You are just too rich on the CO is your problem
Could be the injectors you replaced or a catalectic converter that is hollow or has very little substrate left inside
Could be the MAP sensor
Have you checked codes?
Custom exhaust and a high flow cat make little sense if trying to pass I/M in UT
I was an inspector here in UT for 30+ years
Your air pump is there and working?
You are driving a 5.8 with dual thermactors?
Ford put 2 air pumps on some of them and a big honkin cat for a reason
You may need to register it in Box elder County or another one with no I/M with your mods
With no cat, those run about 4-5 percent on the CO
A working cat gets them down to .06 or so
Good luck
Noted, I will look into some motorcraft plugs. I didn't replace the injectors the PO did. I will look into the MAP sensor. There are no codes, just 111. The air valves didn't work along with the check valves and solenoids, I passed the last couple of years with an improper thermactor system. It only had the one pump in, I replaced it with one from the junkyard due to the last one grenading lol. I took it all out since none of it worked and was taking up room in the engine bay. I will look into some new parts and into hooking it back up. I have thought about registering it in a different county, I will look into it. Very interesting so it seems like this cat is working to an extent. Thank you for your help it is very much appreciated.
Also the year before last it passed, but the PO had hollowed out both cats, so I have no idea how it had passed previously.
Anyways I took out the y pipe and cat, and the cat completely melted. I am trying to upload a picture but it isn't cooperating. My guess is when I was dealing with an ignition system failure it caused unburned fuel to enter the cat and melted it. As I dealt with the spark issue last month, and I had looked at the cat previously and it didn't look like that lol. I will look into getting another one, I am looking at one off of summit racing made by magna flow. This is the one I am looking at, https://www.summitracing.com/parts/mpe-94109?rrec=true.
Yikes. Truck will be faster and better econ with fresh one.
10/10 would investigate how it came to fruition.
So I had an intermittent stalling and ignition system failures and I think that during that time the engine was dumping a lot of unburned fuel downstream. The truck would just die and lose spark so I think the injectors were still firing dumping a ton of fuel into the already hot cat.
I was curious about the catalytic converter that I installed last year, mainly I was wondering if it was getting up to temperature to actually do its job. I can't really stick a thermometer in the cat so I measured the outside temp of the cat and it was 70* F after letting it idle for about 10 minutes. Took it for a drive on the interstate and then measured it and it was at 110*F. Outside temperature is around 40*F. I would think that it would be a lot hotter, the long tubes and y pipe were about 350*F but as soon as it hit the cat it drops significantly. This may be a big contributing factor, I will do some more research into the exterior temperature of catalytic converters but ideally I would like to measure the internal temps.
Just making a full loop back to this, there is some kind of insulator between the honeycomb and the metal casing so that's why the reading wasn't high.
