Second Distributor o-ring on Autolight?
Old Oct 25, 2024 | 03:56 PM
1972-34ton's Avatar
1972-34ton
Rabbit-Hole Researcher
Edit: The second lower o-ring mentioned here is NOT required, and was likely used in error. Some of the kits of misc o-rings that DO have the right upper v-section gasket included others, and perhaps that is why it was stuck on there. Absolutely no reason to use it that I can see.
Original Post:
I just pulled a non-original replacement distributor. It has a second o-ring on this Autolite. Don't know if it is right, or original.
If it was an o-ring, it is squashed to a square-cross-section now. It may have been a thin 1/16 or something like that?
A N*PA assortment of distributor o-rings has one that looks right, and it fits. Not talking about the one up at the top, this one is in the lower part where it seats down in the hole about 4" or so. I'll measure it later...
Owner says it was a replacement back in the 90's. Truck was running ok before. The shaft has a lot of vertical play when out of the engine, about 1/4".
No axial play to speak of. Gear wear looks minimal, with no visible wear band. Roll pins are just fine, not loose. Maybe 10-20,000 on it.
Note: Moderator, feel free to delete this thread.
Old Oct 26, 2024 | 12:48 PM
KO1960's Avatar
KO1960
Pertronix sells a stock looking electronic distributor. If you get one with the Ignitor III, you may want to upgrade the coil as well. My stock distributor has the Ignitor III and the Flamethrower coil. Works great.
Old Oct 26, 2024 | 06:02 PM
DaveMcLain's Avatar
DaveMcLain
An FE doesn't use an O ring to seal the distributor. It uses a ring that looks sort of like a lip seal. Up and down end play in the shaft doesn't really matter. The gear should be able to rest against the block with no preload.
Old Oct 28, 2024 | 01:08 AM
tbm3fan's Avatar
tbm3fan
Whether Autolite or Motorcraft, for an FE, they both look identical.
diggerrigger
Nov 6, 2021 07:52 AM
Boundertom
18
Apr 16, 2020 09:11 PM
djmichael24951
Feb 11, 2014 02:59 PM
chadtexas
Oct 18, 2013 10:30 AM
cparks
Apr 18, 2009 06:57 PM
