Adding a Transfer Flow Fuel Tank
Old Oct 23, 2024 | 10:58 AM
shailey's Avatar
shailey
I'm considering replacing the 34-gallon F350's fuel tank with a 58-gallon tank from Transfer Flow. Can anyone comment on whether this change will void any or all of the Ford factory warranty?
Old Oct 23, 2024 | 11:16 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
It could affect the fuel system warranty, and I suppose they could make a case for things attached to the fuel system.
But, I haven't heard of anyone having any warranty issue.
I doubt they would even pay any attention to the larger tank if you have to bring the truck in for warranty work, unless it is fuel tank related work.
Old Oct 23, 2024 | 11:33 AM
SARDiverDan's Avatar
SARDiverDan
No, it will not void anything because it does not supply fuel directly to the engine. All it does is transfer fuel from the aux tank into the main tank. That's like saying that using a gas can would void your warranty. The only thing you need to consider is if the area you live in allows gravity feed fuel transfer. As some don't, you need to install a fuel pump that will pump the fuel from the aux tank into the main tank. I ran a 91 gallon in my 2002 for 15 years or so. I started out with gravity feed and after a few years, switched over to a holley fuel pump mounted in the bed with a switch on the dash.
Old Oct 23, 2024 | 11:41 AM
BPTS's Avatar
BPTS
I am pretty sure he is referencing the 58 gallon tank for the gas engine SuperDuties. They completely replace the O.E. tank. I do not believe you can lawfully run a transfer tank set up on a gasser.
OP- you running a gasser or oil burner?
Old Oct 23, 2024 | 12:36 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
He is talking about a replacement fuel tank, not an auxiliary tank.
Old Oct 23, 2024 | 01:13 PM
SARDiverDan
Sorry, I see transfer tank and went with it. In regard to replacing your stock tank, it appears thousands have done it and no reported problems with a warranty issue reported so far from what I have seen.
Old Oct 23, 2024 | 02:13 PM
shailey's Avatar
shailey
7.3L gasser. Considering replacing the small-ish factory tank with a larger aftermarket fuel tank
Old Oct 23, 2024 | 02:44 PM
99powerstrokedF250's Avatar
99powerstrokedF250
I'm pretty sure you're correct, you cannot have any gravity transfer tanks on a gasser. I'm not sure pump ones are allowed either, unless it requires you to actually get out of the vehicle to pump the fuel from the aux tank to the main tank. Something about gasoline being more volatile than diesel is.
Old Oct 23, 2024 | 03:37 PM
Grandpop's Avatar
Grandpop
Trailering
When you do it, can you post back and let us 7.3 gassers know how it worked out please.
ohioguychris
6.2L V8
Dec 9, 2020 10:48 AM
jkidd_39
Feb 19, 2010 09:32 PM
BTW
Oct 8, 2003 09:14 AM
