Transmission trouble
Old Oct 20, 2024 | 10:27 PM
bgibson2334's Avatar
bgibson2334
3rd Gear
Hey guys, I’m having some transmission problems with my 2017 f250 6.7 145,000 miles. Truck has been on a weight loss plan with Ampd tunes. Downshift from 5th to 4th is extremely hard. Also a little bit of flare in 6th. And occasionally 1st to 2nd is a hard shift as well. From the information I’ve gathered from this page and other pages it’s looking like a valve body issue. Would be interested to see what you guys think about the issue. Also recommendations for a Valve body leaning towards SPE but wanted to check with you guys to see if you liked anything else better? Thanks in advance.
Old Oct 20, 2024 | 10:48 PM
muisejt's Avatar
muisejt
If you tuned the TCM I would look into that first
Old Oct 20, 2024 | 11:43 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Exactly, very likely the TCM tune was tweaked during tuning.
Old Oct 21, 2024 | 12:21 PM
WXboy's Avatar
WXboy
I'd start simple. Have you changed the trans filter? Most people neglect proper transmission maintenance. I don't care that the manual says you can go 150k. 150k is a LONG time on fluids.
If so, then I'd go to valve body next. 2017 trucks had a lot of valve body issues for some reason.
Third I'd load the STOCK transmission tuning and a 40 HP or less engine tune. AMPD will allow this, I verified with them a few weeks back that their stock transmission file is indeed a Ford OE transmission file.
Old Oct 21, 2024 | 08:01 PM
bgibson2334
3rd Gear
Just changed it now. Going to drive it again in the morning. It was very dark. Good idea with changing the tune. I will try that as well.
yomo50
Sep 28, 2016 05:10 PM
carltonwebb
Dec 6, 2012 11:24 PM
dn29626
Oct 4, 2012 11:11 PM
1982_f150
Feb 16, 2011 09:26 AM
dmc919
Aug 1, 2004 12:02 AM
