West Virginia Chapter Join Chapter, Leader: 5_labsownus
Seized engine
Old Oct 20, 2024 | 08:26 AM
Newbie_66's Avatar
Newbie_66
Seized engine
Despite my lack of knowledge I was able to get a 66 f100 run I g great over last 2 years thanks to you all, mechanics, YouTube, etc. everything was great.
and then, the engine seized on me coming down 77 north in bastian va. So now what?
it was a v8353 3 speed. Garage said with an engine bay that big I had options. Again given I’m a newbie what should I be tho on g about. One hand I’m included to replace with exact same thing a used v8353 - which I’ve found. On the other, given fuel efficiency and other considerations should I consider a swap? If so, what? I hear LS but again I’m not really sure what that all entails. If I get an engine do I also get a new transmission? If i get both even if not a v8 352, does that “simply” replace what I have?
What’s the most economical, easiest way to do this…and get my truck running again.
who rebuild engines or installs engines in wv?
Thanks
Old Oct 20, 2024 | 09:47 AM
DrCharles's Avatar
DrCharles
You could buy a lot of gas for the cost of an LS swap
Quickest and easiest way to get your truck back on the road is to find a good used 352, 360 or 390 and swap it in. No fabrication required.
Old Oct 20, 2024 | 02:58 PM
Newbie_66's Avatar
Newbie_66
ok. That makes sense. Perhaps a dumb question, but if I get just the motor will that connect to the existing transmission I have? Which is the original? I ask because am I looking for just an engine or an engine and transmission? Will it literally be pull out the engine and/or transmission and put in the new one? Are you saying if I went to a 390 which is a bigger engine? I would be fine? Thank you so much.
Old Oct 20, 2024 | 06:10 PM
spurredon's Avatar
spurredon
352 and 390 look identical on the outside, same big block but a bit bigger bore and longer stroke. You could probably use the same carb and all!
You could always pull your engine and rebuild it if you have the time. You can't learn any younger. Lots of willing help here on the forum.
Old Oct 21, 2024 | 09:21 AM
5_labsownus's Avatar
5_labsownus
Good morning Jim, and sorry to hear about the engine.
I would say the simplest and most cost-effective way is to replace the engine with the same or have your engine rebuilt. I am sure there are some engines that will bolt to your transmission. I would check with the people in the Transmission forum and see if they can help with bolt pattern matches!
Like Dr Charles said, swapping in anything else i.e. LS will take a lot of effort and money.
Newbie_66
Oct 21, 2024 01:43 PM
saywhat333
6.4L Power Stroke Diesel
May 27, 2021 05:59 PM
sdtrucking
Dec 13, 2019 07:47 AM
Alex Cook
Jul 7, 2015 10:48 PM
jpfreak
Oct 6, 2005 03:22 PM
