Tail light ideas
The light output of these old tail lights is terrible but I didn't want to screw up the look of the back of the truck so wanted to keep the original tail light lens.
To remedy this I designed and 3D printed a tail light housing that used 3 lighting circuits like modern cars. 1 for turn signal and flash, 1 for tail light, and 1 for brake light.
i used a halo ring for the tail light and a 1157 .led bulb for the brake and turn signal.
let me know what you think.
1157 LED bulb
70MM red LED halo
bayonet bulb holder, ground and 2 circxuits
3D printed housing that mounts into existing fender opening without modification in any way slot at bottom of image is where halo wires go thru. 3D Printed in silver PETG
rear view of housing showing bayonet receiver for bulb holder to lock into.
Assembly mounted in truck showing housing, halo light and 1157 bulb
view of back of truck with tail light on.
view with tail light and brake light. can't upload movie clip showing turn signal
1157 LED bulb
70MM red LED halo
I would like to see this and see how much you would ask for a set for my resto. As ideas are still abound in my mind for my truck.
- Preston
i will get you a new pic and post it. when you get closer to needing a set let me know. just plastic costs and printer time. you can order all the other parts on amazon and i can link those in.
happy building.
I thank you. I will let you know as soon as I get closer to the time.
