Sponsored by: Real Truck
Odd tail light led
Old Mar 22, 2024 | 01:37 PM
bevanet's Avatar
bevanet
2nd Gear
Odd tail light led
My 2012 F250 6.7 XL has this odd led at the bottom of the tail light assembly below the tail/brake bulb. I haven't been able to get it to light up with the tail lights, brake, turn, hazard or reverse lights. Does anyone know what it does, or how to turn it on? It says HAL09-RL3 inside the clear cover.
Old Mar 22, 2024 | 02:51 PM
Don Ridley's Avatar
Don Ridley
Could be a rear fog lamp. Do you have two fog light switches?
Old Mar 22, 2024 | 05:53 PM
bevanet's Avatar
bevanet
2nd Gear
I was thinking that it might be a fog lamp, but it is a pretty bare-bones truck without front fog lights and I don't see any switches for fog. It was previously owned by a reservation. I now recall they had some type of flashing light on the roof that the dealer removed. I'm guessing these were part of a flashing system they used. Since these bulbs are held in by screws instead of twisting tabs and I can tell the hole is not factory, they must be aftermarket. Next time I'm under it I'll see where the wires go.
Old Mar 22, 2024 | 06:44 PM
Roofing05's Avatar
Roofing05
2nd Gear
Definitely a switchback, probably dealer installed. A lot of construction companies run these types and some in the headlights too, it was probably used as a reservation “law enforcement” truck.
Old Mar 22, 2024 | 07:15 PM
woody367's Avatar
woody367
It is a aftermarket led strobe light someone installed.
jstihl
Jan 2, 2024 05:52 PM
sandxssun
Feb 16, 2023 04:47 PM
KU4OJ
Jun 4, 2022 01:47 PM
carrfamilynj
21
Sep 13, 2018 06:37 AM
DrewF
6.7L Power Stroke Diesel
Sep 13, 2011 11:14 PM
