Do remote features drain the batteries
truck not used yesterday
30w solar panel on dash facing south
wired with a quick disconnect sae connector direct to the battery
sunny day yesterday
45 degrees over night
end of day voltage yesterday was 12.7
this morning the voltage was 12.34
so I am loosing almost .5 volts over night.
Full sun today so I’m sure I will be at 12.7 by end of day.
I understand that the computer will shut stuff down when volts falls below 12, but having a battery at 11.99 volts most of the time if the vehicle sits a few days is not good for battery life.
I bought new batteries a few days ago because in the last 30 days I go the message a few times that the batteries were disconnected to save power or something to that effect . I had to jump start with an ion jump pack twice.
the old batteries were 4 year old motorcraft 850cca flooded batteries. The prior batteries were 2 year old motorcraft 750cca batteries.
I think a few more days of checking end of day vs morning next day voltage …then…I will probally shut off the spy feature. I don’t need an app to tel me where my truck is or if it’s locked or not. I can key fob remote start if I want and don’t need the app to remote start. Etc, etc
then I will compare end of day vs morning voltage and see if it makes a difference.
maybe I’ll do a chart.
I’m concerned because of the need to jump start twice on the old batteries and feel the 850cca batteries should have lasted longer if it were t for the ford spy system battery drain .
I could be wrong.
sunny day yesterday
I could be wrong.
The advantage to the app is you don't have to be in range of your key fob for the remote start to work. My wife and I use it frequently at work during the winter.
In my experience and opinion (take it for what it's worth), more CCA is ALWAYS better, and 850's are the MINIMUM I would put in ANY vehicle. If it will physically fit, I typically go for a 950 CCA battery or bigger. On today's vehicles, a 750 is just too small to get any longevity out of. Even my old 6.0's had 850 or 950 CCA batteries.
this makes sense
the more cca’s the easier we will survive daily batterie drains .
if the computer turns on battery saver at 11.99, that’s a 40% state of charge.
Each phone can monitor up to 4 monitors.
For the boat I have an old phone that monitors trolling motor (3) batteries.
Bluetooth Battery Monitor,Wireless 12V 24V Automotive Battery Load Tester with Charging & Cranking Test & Alarm for Solar Power Systems/RVs/Motorcycles/Boats/Cars/Trucks
but the dual ford 6.7 batteries will count as one since they are both connected on positive side…they will always read the same.
interesting
i don’t get that message in the ford pass app on my 2019.
so at this point I am leaning to throwing the 30w solar panel on the dash if I’m not going to use the truck for a few days. I know it will start with out the solar charger , but I’d rather not have r voltages drop below 12v .
