How much drain is too much?
I seem to have traced the drain to fuse #8. With the doors closed and hood bulb out, I measured 127mA drain from the battery. I traced most of the drain fuse #8 which was pulling 116 mA. To confirm, I checked the drain from the battery with #8 out and got 11.4 mA.
Fuse #8 covers all interior lights, outside mirrors, clock/radio memory, speedometer, warning buzzer, left and right door switchs, the engine compartment light and as I discovered, the remote keyless entry system.
I noticed that there was some sort of relay in the keyless entry system as I was pulling #8 fuse. You can hear the relay clicking on and off as voltage was applied.
When I pulled the connection to the keyless entry module, the current accross #8 fuse dropped to 56 mA.
Do any of these numbers sound normal or do all seem out of line? If there is a problem with the keyless entry, is this only 1/2 of my problem?
The other thing I thought was interesting is that the drain seems to increase with time. In 5 minutes, the drain at the battery went from 127 mA to 145 mA. Could this be some indication of the source?
Thanks
They say the max parasitic current draw most cars ever have is 30ma. Typical current draw is 7-12ma.
What I didn't know that even with these low draws, the battery can still be run down by just sitting in a very short time. Depending on the condition of the battery, it can be as short as 15 days, but typical is 20-30 days, before the battery goes low enough before it won't start the vehicle. They are recommending dealers disconnect the battery - cable if the car is going to be sitting for more than 20 days.
