Rear Suspension
Old Oct 19, 2024 | 02:28 PM
mitch122786's Avatar
mitch122786
Trailering
Originally Posted by Conanski
Does the front end have any negative camber now? If it doesn't then the springs aren't sagged. The rear of the truck definitely looks higher than normal for a 2wd, it's possible a PO installed heavier rear springs, this could be corrected by removing some leafs.
I don’t believe it does. My great uncle bought it new and my grandfather had it after him. I don’t think they put anything on the truck. I got it bone stock. I do want it level, but I want to bring the front up, not lower the back. I may put new factory springs in case these are sagging and so they will be new. I’ll add spacers after if it needs to go up more.
Old Oct 19, 2024 | 05:41 PM
Junktownbill99's Avatar
Junktownbill99
How mine sits on 33s, only has slightly longer springs in the front, any more, and I doubt it could be aligned.
Old Oct 19, 2024 | 06:12 PM
mitch122786
Trailering
That’s my ideal height right there. So do I add 1.5” springs?
Old Oct 19, 2024 | 06:16 PM
Junktownbill99
I have Moog CC824 springs ($100 on Amazon) but do some research, there may be clearance issues on a 2wd, but they should otherwise fit.
(I noticed in a previous picture, you are missing the plastic spring isolater pads, so if you replace the springs, order some of those to)
Old Oct 19, 2024 | 06:24 PM
mitch122786
Trailering
Thank you!
Old Oct 22, 2024 | 05:42 PM
mitch122786
Trailering
Okay, so I jacked up my truck and took all of the weight off of the springs. They measured approximately 15”. With weight on them they came in at approximately 12”. Would this be normal, or considered sagging springs? Rough Country has 1.5” leveling springs but they are also 12” with weight on them. I don’t know what to do.
Old Oct 23, 2024 | 01:22 PM
Junktownbill99
Can't be too much help there, as there are so many different types of springs, OE and aftermarket.
This is the difference in my coils, but I don't know what factors produce a difference between our OE springs.
1979 F150 Supercab
Jan 22, 2022 10:55 PM
dziwei
May 23, 2021 06:57 AM
stewart460
Jun 29, 2009 05:38 PM
fordstest
Feb 25, 2004 03:26 PM
Neil
1978 - 1996 Big Bronco
Nov 19, 1999 03:28 AM
