swapping suspension
Old Feb 24, 2004 | 09:48 AM
fordstest's Avatar
fordstest
swapping suspension
I am restoring a 78 f250 and wanting to get the front end up is it possible to put a highboy suspension on my truck? If it is, do I need to just put the springs on the front and block the rear or what?
Old Feb 24, 2004 | 10:00 AM
78fordman's Avatar
78fordman
I would just get some blocks, they are pretty cheap. A highboy is only like a 2 inch lift. You should be able to go a 4 inch with too many mods.
Old Feb 24, 2004 | 11:41 AM
85351ho's Avatar
85351ho
if you wanted your truck to sit like the "highboys" do stock, you just need a 2 inch lift....highboy front springs will bolt in your front, but the rears use different width springs and blocks
Old Feb 25, 2004 | 03:19 PM
fordstest's Avatar
fordstest
swapping suspension
thanks for all the info guys.
Old Feb 25, 2004 | 03:26 PM
78Extended's Avatar
78Extended
front blocks
blocks in the front suspension is very dangerous and should never be used. i think you could use a high boy spring to lift your 78 an inch or two. if there is any high boy guys out there running stock front spring maybe they could tell us how much arch a stock high boy front spring has and you could compare it to the 78 springs
Gater180
Mar 2, 2014 06:49 AM
awils961
Mar 31, 2011 11:08 AM
fsunoles
1997 - 2003 F150
Mar 26, 2009 08:24 PM
fordf250honduras
Oct 15, 2006 08:12 PM
