Speedometer connection under dash? FIXED
Old Oct 15, 2024 | 05:22 PM
EVOFXR's Avatar
EVOFXR
4wd Low
This afternoon, I replaced my pedal box. I had a difficult time getting the old one out and the new one in. Sometime during that mess, I must have messed up the speedo connection under the dash. When I put everything together, all of it works except all of a sudden, my speed and odometer are dead. Is there a connector I could have bumped or damaged under there? I can follow a signal and am pretty good with wiring. I’m just hoping there’s an easy way out before I start chasing wires. Thanks!!
edit - turns out, it was the other speedometer fuse. My fuse panel says speedometer for fuses 8 and 18. Number 8 was burned.
Old Oct 16, 2024 | 07:36 AM
Yeoman's Avatar
Yeoman
If the Speedo works after changing the fuse, then the moral of this story is to disconnect both batteries before messing with electronic controls.
thehedonist
Jun 13, 2013 07:15 AM
top that
Dec 13, 2005 09:36 AM
mrjbnak
Aerostar
Dec 16, 2004 07:32 PM
QCIGUY
Electrical Systems/Wiring
Oct 2, 2004 10:29 PM
jgrey
May 1, 2000 04:47 PM
