Whole side not hitting
Old Oct 15, 2024 | 02:16 PM
Sam'struckrepair's Avatar
Sam'struckrepair
1st Gear
I have a code 1291 one injector on the left bank ohms out at 13.2 would that be the short to ground or positive it is talking about when I look up the code all others ohm out fine .
Old Oct 15, 2024 | 02:59 PM
Pikachu's Avatar
Pikachu
13.2 ohms would be closer to open than short in the context of an injector solenoid. How many miles on the injectors? Have the armature plates been shimmed in the past? Check the underside of the wiring harness that connects to the engine from the chassis. They are known to chafe on the valve cover.
Old Oct 15, 2024 | 03:06 PM
Kintla's Avatar
Kintla
One bank isn't firing?
I'd be looking for chaffing on wire harness at valve cover or the UVCH connector. Ohm out wiring from 42 pin to UVCH.
Old Oct 15, 2024 | 04:32 PM
RacinJasonWV's Avatar
RacinJasonWV
I’ve read on here that a short on 1 injector (or associated wiring) will shut down the IDM for the entire bank.
Just something to keep in mind as you work through this issue.
Old Oct 15, 2024 | 09:06 PM
udsuth78's Avatar
udsuth78
A P1291 is for a high side(hot) short to ground. Where are you testing from and what is connected or disconnected when you were testing? Does the code come back after it's cleared?
brad5428
6.7L Power Stroke Diesel
Dec 23, 2023 12:23 PM
StrummerK
Apr 29, 2021 10:37 PM
mason6540
Oct 18, 2010 04:25 PM
Supercab
Jun 3, 2010 04:37 AM
seanlleiker
Jan 22, 2007 09:34 AM
