steering stabilizer
Old Oct 16, 2024 | 09:28 AM
TX Crawler's Avatar
TX Crawler
I've had good luck with the King stabilizer. It can be rebuilt when needed, but it's not a lot cheaper than just buying another one -- they can be found for $300ish.
Old Oct 16, 2024 | 06:50 PM
johndeerefarmer's Avatar
johndeerefarmer
Originally Posted by cpobst
I've said this in every thread about steering stabilizers. The factory one is not in the most ideal position. It needs to be on the same plane as the steering itself. It's why the older Super Duties and any serious off road vehicle has them mounted on the tie rod and axle housing. The Fox ATS is terrible, if you tighten it enough it proves my point because as the suspension travels up and down it will move your steering wheel left and right. Ditch the factory location and install a single or dual setup like I mentioned.
What have you used or recommend? Thanks
Old Oct 16, 2024 | 07:59 PM
cpobst's Avatar
cpobst
I had a PMF setup on my 2017 F250 and I have the same setup on my 2022 F450. I know others make them also, I just like their products.
Old Oct 17, 2024 | 09:33 AM
nitebreeze's Avatar
nitebreeze
I went with a Kelderman Fox 2.0 dual steering stabilizer on my F250 (so i didn't have to measure anything). Five years of perfect aweome steering and handling so far.
Old Oct 18, 2024 | 06:43 AM
shailey's Avatar
shailey
I changed to a Bilstein steering damper when I swapped the factory shocks to Bilstein 5100s. This was a 2024 F350 Lariat with 4,400 miles, I’m happy with the improved ride and the more steady steering resulting from the change.
Old Oct 18, 2024 | 08:19 AM
PatrickStapler's Avatar
PatrickStapler
Interested in hearing why you made this change with so few miles. Were you displeased with the ride quality or comfort of the OEM shock? And how would you compare the 5100's specifically from a soft or harshness perspective to the OEM shocks?
Old Oct 18, 2024 | 09:13 AM
acdii's Avatar
acdii
I did the same thing with an F150 that had FX4. The truck would hop all over the road on cloverleafs if there were bumps. The 5100's made the truck stick to the road without all the wheel hop. Noticeable improvement in ride and handling.
Old Oct 18, 2024 | 09:20 AM
PatrickStapler
The reason I ask, I replaced the OEM shocks on my '15 F250 with 5100's at roughly 150K miles (when I got the truck). So I never really had a true comparison until now with my '23 F350 with OEM shocks. I can say my wife loves the ride of the '23 F350 compared to the '15 F250 with Bilstein's. Honestly, I do too...and I love Bilstein shocks, we run them on both race cars and they are great shocks. So I am a bit hesitant when it comes time to replace the shocks on the '23.
Old Oct 18, 2024 | 05:26 PM
johndeerefarmer
Stock tires?
Old Oct 18, 2024 | 05:27 PM
johndeerefarmer
I always put Bilstein shocks on my trucks as soon as I get them.
4600's on my F150's and 5100's on my SDs.
Old Oct 19, 2024 | 08:25 AM
nitebreeze's Avatar
nitebreeze
Stock tires?
No, the stock tires were replaced with 35x12.5/18 on 18x19 +18, just prior.
Old Oct 19, 2024 | 09:56 AM
Charlie98's Avatar
Charlie98
I do notice a bit more bump steer in my '23.
Not going to change much of anything on pavement.
My 2023 was my first 4WD in many years... here in the Dallas area, the roads are so horrible, my truck is jumping all over the place in the right conditions, something my 2WD trucks never did. The factory shocks are already shot (at 24K) so I'm guessing the damper is, too. A new Bilstein is in my cart... just waiting on funds. It can't hurt.
I do have a question, however...
If the OEM part is a damper, which I agree, why would they charge them with gas? ...unless you have a dual damper setup, with them opposed to each other?
Old Oct 19, 2024 | 10:03 AM
  #28
Overkill2's Avatar
Overkill2
That's interesting .When I replaced the stock stabilizer on my '15 with the Bilstein, I noticed a huge difference. Now admittedly, mine was considerably older than yours.
I'm going to have to keep that in mind for my 16 as it still has the original stabilizer with no issues but I rock the OEM 275/65R20 size tires, except in winter when I use a set of factory steel 18s with 275/70R18s.
But if there is any issue with any front end suspension component, no steering stabilizer or dual set will compensate for that... DW is always a threat.
Old Oct 19, 2024 | 11:59 AM
  #29
PatrickStapler
Affirmative! I can say after I replaced my steering stabilizer, shocks, caster+ bushings, the rest of the entire steering parts, and tires, I still occasionally got DW on my ‘15. The ONLY thing that eradicated DW was replacing the passenger lower ball joint and the steering link bar that connects it to the driver side frame.
Old Oct 19, 2024 | 04:12 PM
  #30
acdii's Avatar
acdii
Track bar and ball joints are usually the very first suspects in DW cases. Anything that can make the front end oppose itself will set it off.
