Turbo oil
Old Oct 14, 2024 | 03:28 PM
bak2004's Avatar
bak2004
Trailering
Turbo oil
Hi, I have a 2018 ps, my current turbo has shaft play and will be getting replaced with a journel bearing, currently in is a spe ball bearing turbo, my question is what causes turbos to go bad, and if it is oil starvation is a journel bearing not gonna work is oil flow is low?
Old Oct 16, 2024 | 12:25 PM
senix's Avatar
senix
shutting it down while in full spool, thereby starving it of oil is one thing to consider.
Do you let idle if you have been working the motor?
Capt'n Jack
Jun 18, 2021 09:32 PM
coltdog
Jan 16, 2020 08:37 PM
menmy02x
May 6, 2015 10:18 PM
JT250
13
Aug 21, 2013 11:10 PM
wadestreet
Jul 28, 2011 01:06 PM
