Parasitic Draw
Old Oct 14, 2024 | 11:09 AM
Brian7.3's Avatar
Brian7.3
4wd High
Parasitic Draw
I noticed that when I let me truck sit for more than a 4 days, my batteries are dead. So I recharged that and found I have a draw of about 250mA being drawn off the batteries. I started pulling fuses and found that it is coming out of Fuse 110 which is a 50A fuse for the ignition switch. Where would be the best place to start for this? Is it possible that the key switch has a short in it?
Thanks
Old Oct 14, 2024 | 01:35 PM
bismic's Avatar
bismic
What'cha driving there Brian?
Old Oct 14, 2024 | 05:38 PM
Brian7.3's Avatar
Brian7.3
4wd High
2004 F350 6.0
Old Oct 14, 2024 | 06:11 PM
TooManyToys.'s Avatar
TooManyToys.
A direct short would blow the fuse, so there has to be a draw in the breakout circuits past the 50a fuse. I don't have the '04 diagrams, but I'd check through the other fuses for having power through them.
Old Oct 14, 2024 | 06:57 PM
bismic's Avatar
bismic
If the F2.110 circuit is the same as my '06, then I would pull the 15A Instrument Cluster fuse (mine is fuse 33) and see if that stops the draw.
EdIt - checking what little I have on '04 wiring, the Instrument Cluster fuses look to be 35 and 41 (both 10A). They are likely candidates.
Old Oct 14, 2024 | 08:07 PM
Brian7.3's Avatar
Brian7.3
4wd High
Alright thanks,
I'll get working on that tomorrow and report back
Old Oct 14, 2024 | 11:20 PM
kbeefy's Avatar
kbeefy
Near as I can tell, fuse 110 feeds fuse #25 & 26 when in the run position only.
If you pull #25 and/or 26 and the load drops, I would assume that your ignition switch is shorting out.
Old Oct 14, 2024 | 11:21 PM
kbeefy's Avatar
kbeefy
Sorry thats so blurry
I just noticed it also feeds fuse #27, so add that to the list.
Old Oct 14, 2024 | 11:26 PM
kbeefy's Avatar
kbeefy
Hopefully clearer...
Old Oct 16, 2024 | 05:36 PM
Brian7.3's Avatar
Brian7.3
4wd High
So went and did more testing, I pull Fuses 25, 26, 27, 35, and 41 but the draw was still there. I looked at a schematic some more and tried all the other fuses in the fuse box, but none of them stopped the power draw. Does that mean that maybe the key switch is bad?
Thanks
Old Oct 16, 2024 | 08:00 PM
kbeefy's Avatar
kbeefy
Any aftermarket wiring, alarm or autostart that might be tied into the ignition switch?
Old Oct 16, 2024 | 08:24 PM
Brian7.3's Avatar
Brian7.3
4wd High
It has an aftermarket radio and back up camera, but I would think that if it was the radio then pulling the radio fuses would have stopped the power draw.
RigCity
May 14, 2023 06:14 PM
lostislandguy
15
Mar 8, 2023 01:04 PM
Dmart64
Apr 27, 2022 06:35 AM
2manygoats
Oct 28, 2017 08:55 PM
devildog_0431
May 23, 2006 05:01 PM
