2005 excursion cruise control will not activate
Old Oct 13, 2024 | 05:02 PM
jurish's Avatar
jurish
I don;t know exactly when it stopped working BUT when I try to turn on cruise control, I dont get the light on the dash anymore.
I checked the manual and I can't find a fuse for it in the panel.
What would keep the cruise from powering on?
The excursion is a 2005 with 6.0L
Old Oct 14, 2024 | 08:44 AM
LX Sport's Avatar
LX Sport
I had a brake light out that was a problem. Also check the switch's on the brake .
Old Oct 14, 2024 | 09:11 AM
jurish's Avatar
jurish
I might have used the wrong word. My cruisecontrol won't "turn on".. I don't get the light on the dash when I hit the ON button in the steering wheel.
Old Oct 14, 2024 | 10:40 AM
robert_l_ross's Avatar
robert_l_ross
Check the cruise control release switch.
https://www.rockauto.com/en/moreinfo...4fPCoCxrwvAdbM
Old Oct 14, 2024 | 10:42 AM
jurish's Avatar
jurish
Its not going to be that,. That would prevent you from setting cruise.. Mine wont even power on.. There has to be a fuse somewhere.
Old Oct 14, 2024 | 11:18 AM
LX Sport's Avatar
LX Sport
I think the indicator light only comes on after the speed is set. If the switch on the brake is stuck it will not set the speed.
3. Press the SET ACCEL control and release it. 4. Take your foot off the accelerator pedal. 5. The indicator light on the instrument cluster will turn on.
Old Oct 14, 2024 | 02:47 PM
MoBill122's Avatar
MoBill122
Papa Smurf
Hopefully you have replaced the Cruise Control Switch, as that was the switch on brake master cylinder that would short out.... burned up a lot of gas burners back years ago.
Probably could unplug and put a jumper on contacts, just to see if it works that way.
Old Oct 14, 2024 | 04:16 PM
01__Excursion's Avatar
01__Excursion
On my 2001, the cruise light does not illuminate till the cruise is set and actually regulating the speed. So when set for Cruise and I hit the brake, the light goes out, cruise stops, but the system is still on if I hit resume, or the set button.
Old Oct 17, 2024 | 06:36 PM
Pickupmanx2's Avatar
Pickupmanx2
Veteran: Marine Corps
I should've taken pics as they would help, but since I'm an X'er, I don't think about pics till after the fact 🤦‍♂️ On my new to me 00 Ex, I had no cruise, bought new CCS as there was a little seepage on it, no worky, then I followed the wiring, it had old recall wiring with fuse installed, fuse was all corroded, I'm guessing from the seepage from the CCS, had 2 of the recall wiring harness Ford mailed me years ago for some of my trucks I never put on, cleaned everything up, rplc'd it with new unused harness, viola. Just bought an 02 Ex for my BIL, same issue, and since he was driving it back to TX I used the last spare harness I had, CCS had been rplc'd recently by PO but not the harness, cleaned and swapped in new one, now it has cruise.
I wish I'd taken a pic of the Ford part # on it for you, the CCS was about $65 I think from Napa, I suggest doing that with new harness/fuse setup.
And yes, unlike the newer cars, the CC light doesn't come on until the cruise is actually set, since I also have my 02 F350 7.3, I'm used to that, but some folks with newer cars don't know that.
Dgmisho12
Modular V8 (4.6L, 5.4L)
May 28, 2015 10:11 AM
Ford'05HG
Oct 13, 2014 08:52 PM
BigE2000
Aug 21, 2011 07:14 PM
silentsoul
Aug 1, 2009 11:28 AM
