CONVERTING TO AUTO
Old Oct 12, 2024 | 10:03 AM
Rad082625's Avatar
Rad082625
CONVERTING TO AUTO
My 1962 F250 4x4 is in great shape overall with a strong 292 Y block backed by a 4 speed. I get tired of shifting due to a left leg prosthesis so I would like to convert to an auto tranny. A C4 with an adapter would bolt up to the motor with no problem and I would need a new trans crossmember since the 4 speed tranny used the bellhousing side mounts which I can't. I think the overall length of the Y block and C4 will still be short enough to couple to the T case short shaft so what i need to know is any other issues I might face with my project such as: case fill or pan fill C4, T case shifter linkage, tranny linkage, etc......Bob
Old Oct 13, 2024 | 06:50 AM
53deere's Avatar
53deere
The current setup uses a single point mount on the front of the engine and side mounts on the bellhousing. If you do away with the bellhousing mounts and go with a tail mount on the C4 you need to have side mounts on the engine.
Old Oct 13, 2024 | 07:40 AM
Rad082625's Avatar
Rad082625
Thanks I hadn't thought of that, good to know...Bob
Old Oct 13, 2024 | 07:42 AM
Rad082625's Avatar
Rad082625
How have all the guys that have put an auto in back of a Y block deal with that issue ?
High76boy
Nov 16, 2013 11:24 AM
cornfedp
Jul 4, 2009 07:05 PM
89frankenford
Oct 8, 2007 10:54 PM
60f100trk
Mar 16, 2002 03:53 AM
