RABS code 16 ????
Old Oct 10, 2024 | 10:16 PM
Scott in TX's Avatar
Scott in TX
RABS code 16 ????
94 f350 7.3 idi
So my abs light came on the other day
i had vacuum pump and master cylinder replaced a couple months ago and brakes have been very good
when I started the truck the brakes felt a little soft, noticed the abs light, drove around the neighborhood and put it up
ran the diagnostic test with the jumper wire and it blinked 16 times (including the long one at the end)
googling the codes 16 or more flashes should not occur issue
any ideas ???
I hooked it back up and started the truck, the light was off and even after a couple pushed on the pedal it didn’t come back on
Old Oct 10, 2024 | 10:27 PM
wwhite's Avatar
wwhite
16 - would be a single blink, pause then six blinks.
16 blinks in a row doesn’t make sense afaik.
Old Oct 10, 2024 | 10:34 PM
wwhite's Avatar
wwhite
Hmm, another thought, idi is completely mechanical? Computer only runs transmission control correct?
Old Oct 11, 2024 | 06:34 AM
rla2005's Avatar
rla2005
RABS flashout codes via the ABS lamp are not the same procedure are the PCM flashout codes.
The code consists of a number of short flashes and ends with a long flash. Count the short flashes and include the following long flash in the count to obtain the code number. For example, three short flashes followed by one long flash indicates Flashout Code Four. The code will continue to repeat itself until the key is turned off. It is recommended that the code be verified by reading it several times.
More information:
RABS Codes
RABS Flow Chart
RABS Troubleshooting
All courtesy of Steve83
Old Oct 11, 2024 | 06:35 AM
rla2005's Avatar
rla2005
Correct.
Has nothing to do with the Rear Anti-lock Brake Systems (RABS).
Old Oct 11, 2024 | 06:37 AM
rla2005's Avatar
rla2005
RABS Code 16 info from Subford:
Yellow Rear ABS Warning Light Flashes 16 Times When Retrieving Diagnostic Trouble Codes (Code 16)
Possible Source(s):
No codes stored in anti-lock electronic control module.
Action(s) to Take:
STOP. Rear anti-lock brake system functioning properly.
Clipped from this thread: https://www.ford-trucks.com/forums/1...l#post19255809
Old Oct 11, 2024 | 08:58 AM
Scott in TX
thanks for the replies,
I was confused because 16 on the codes chart says "should not occur" and i read that as it's not possible,
after reading the instructions again I may have tested it wrong,
I had it grounded when I turned the key, when I ungrounded the ABS light started flashing, 15 short and one long
the instructions say to turn the key, then ground / unground to get the code,
hopefully this afternoon I'll get back at it,
Old Oct 11, 2024 | 01:01 PM
rla2005's Avatar
rla2005
Ford RABS-I systems, 1992 and older, Code 16 description states it should never happen. Ford RABS-II, which has the capability to store codes the Ford Service Manual states this for Code 16:
Old Oct 11, 2024 | 01:08 PM
Scott in TX
thanks, that's very helpful, I appreciate it
Scott in TX
Oct 10, 2024 08:30 PM
hkerble
Mar 29, 2024 08:47 AM
Ad_Brack
Oct 13, 2021 04:38 AM
kaised
1978 - 1996 Big Bronco
May 30, 2005 03:08 PM
diesel_988
Apr 11, 2005 01:16 PM
