How do you bypass fuel tank switch on frame???
yellow with turquoise (smaller diameter)
yellow with white (smaller diameter)
purple with yellow (thicker)
red (thicker)
brown with white (thicker)
I've been all over the interweb and cannot find an easy schematic that shows/tells wire colors. I'm understanding that the yellow with white stripe is the signal wire from sending unit to gauge. But sending unit has 2 contacts. Do I just use the thinner yellow wires and splice them directly from sending unit to frame wire loom? Or do I need a ground and signal wire?
Thanks in advance!!
Chris
red (thicker)
Thanks in advance!!
Chris
This thread should have the info you need.
https://www.oilburners.net/threads/f.../#post-1099296
Charlie
I also recently changed the fuel tanks out to manual control valves, and had to figure this gauge sending question myself.
It is very easy actually, it's just that there is confusing looking, and little information about how to wire it up.
This being the only occasion that I ever touched that accursed FSV, and had a pleasant time of it.
Such a horrible spot to access and work on, but anyway, I deleted it.
But as you know, or have found out, that motor the slides the fuel selector port also slides the contact points for the gauge sender up and down, so if the gears are jammed, then the tank selector switch also won't work properly.
Anyways, the wiring is super simple. Looking at the attached wiring diagram will explain how it works.
Pull the electrical plug out of the FSV, and look at it like the shape of the letter D.
There are 5 pins, starting with 1 at the bottom and 5 on top.
Pin 4 is the output wire to the fuel gauge.
To pull your reading off the front fuel tank, simply insert a jumper wire between terminals 3 and 4.
To pull your reading off the rear fuel tank, simply insert a jumper wire between terminals 4 and 5.
It's been 2 days, and you've probably already solved the problem, but yes, it really is that simple.
Thanks!!
