Disc brake conversion issues
Old Oct 9, 2024 | 05:57 PM
Moonlightford's Avatar
Moonlightford
1965 f 100, long bed, no power steering
Members,
about a year ago I did a disc brake conversion, pretty simple, everything worked great.
NOW!, when driving it’s silent, when i step on the brake I hear, thud, thud, thud. If I release the pedal, it goes away
It’s NOT a rapid clicking, I’d say it’s a thud every revolution. Probably less then 1000 miles on the system.
My uneducated guess may be something loosned up? A fast look under didn’t see anything.
Any suggestions?
Old Oct 9, 2024 | 06:20 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Ensure that the caliper bolts are tight. Loose caliper bolts can cause a thudding noise when the brakes are applied.
Check the bolts on the caliper bracket as well. These can also become loose over time and cause noise.
Suspension Components: Inspect the suspension components for any wear or looseness. Worn suspension parts can sometimes cause brake-related noises.
Check the rotor surface for any signs of corrosion or debris. Sometimes, corrosion can build up and cause a thudding noise when the brake pads make contact
Old Oct 9, 2024 | 06:37 PM
AZSCAWPION's Avatar
AZSCAWPION
If the sound increases/decreases with wheel speed would first suspect worn pads. Worn/warped rotor also would be suspect. Can you feel it in the pedal? Also, are you sure it's the front brakes? If it is the front you'll likely hear it just lightly touching the pedal whereas if it's the rear you'd be into the pedal a bit more. Take a friend for a whirl and have 'em hang their head out the window or better yet, have 'em ride in the back to help determine if front, rear, left or right if you're not sure. Maybe can pin it down to 1 wheel.
Old Oct 9, 2024 | 07:16 PM
Moonlightford
I am positive it’s the front drivers side. I did not feel any pulsating in the pedal. The good news on this problem that almost all kits use a D-52 caliper and the brake pads are everywhere. I am hoping it’s just loose, if not then calipers and pads. I’m hoping I don’t need to contact where I bought it for rotors. I’m not sure if there an off the shelf item or custom.
Old Nov 1, 2024 | 03:24 PM
Moonlightford
Members,
I figured it out.
l took the wheels off and noticed a wear spot on the inside of the wheel. I looked at the caliper and saw a wear spot on that as well.
I took my grinder and ground it ever so slightly., Drivers side. Noise is gone. Why it took so long to present itself? Who knows. Maybe cause I drive it about 50 miles a month. I now know why the kit says certain wheels may or may not work
Old Nov 1, 2024 | 03:38 PM
mterickson's Avatar
mterickson
Originally Posted by Moonlightford
Members,
I figured it out.
The calipers slide side to side as they operate and their position changes as the pads wear, rotors get broken in, etc. You may have had enough clearance initially but as everything broke-in, pads wore a little bit the caliper shifted around and made contact with the wheel.
I did a rear disc conversion on my '79 and had to clearance the calipers to clear the 15" factory steel wheels, I decided to install 16" wheels designed for disc brakes later on to avoid any future clearance issues as the pads and rotors wore. I still ended up needing to add clearance to the brake pads after initial break-in due to the ears of the pad rubbing on the rotor hat. Didn't hear it driving forward, but you could really hear it backing up when the caliper shifted ever so slightly and allowed the ear to rub on the rotor. That was more a whine/squeal though instead of the thud that you heard.
It's always something when you modify OEM components, glad you found your culprit.
Old Nov 2, 2024 | 06:24 AM
Moonlightford
I thought about what you said and it all makes sense now. Thank you for your input
lshort
May 31, 2024 04:16 PM
sxgriff
Aug 6, 2023 02:15 PM
Caveman2851
May 17, 2012 11:06 AM
duane
Nov 29, 1999 09:52 PM
