9" Disk brake conversion parking brake
Old May 31, 2024 | 08:50 AM
lshort's Avatar
lshort
I was looking at a 9" disk brake conversion kit from Summit that comes with 2 parking brake cables, can anyone tell me if this connects to the the rest of the stock cable OK and how does this type of conversion work OK?
Old May 31, 2024 | 10:17 AM
85e150's Avatar
85e150
The parking brake is the weak link in the conversions. It should connect to your oem cables upstream somewhere.
Old May 31, 2024 | 10:32 AM
lshort's Avatar
lshort
One reason that I dd not do a disk rear when I built the truck is I did not know how well the emergency/parking brake worked, I insist on having a operational parking/emergency brake
Old May 31, 2024 | 11:37 AM
85e150's Avatar
85e150
IMO high end shoes, good adjustment and proper bleeding and assembly for your rear drums will give you all the brake you need on the back end. Plus if you set that parking brake it will hold.
Good luck!
Old May 31, 2024 | 12:54 PM
lshort's Avatar
lshort
Good luck!
I may just stick with what I have, not sure yet
Old May 31, 2024 | 01:22 PM
52 Merc's Avatar
52 Merc
I would have to agree with the super moderator here. Strictly being a voice of reason, our trucks typically weigh under 3500 pounds, have in excess of a 60% front weight bias, and over 60% of the braking is done by the front brakes. Our trucks are rarely ever used for any kind of heavy duty or load bearing work. Rear discs in our applications are 90% for show, rather than go, or non-go, as the case may be. There's a lot of other places one can drop a grand that would be of far better benefit, imho. YMMV.
Old May 31, 2024 | 04:16 PM
lshort's Avatar
lshort
thanks for that, my truck never hales much more than a couple lawn chairs and a cooler.
hoffy
Sep 27, 2022 05:18 PM
Lulu1957
Dec 24, 2021 09:20 PM
77ford250
Jul 24, 2020 07:50 PM
86F250 460
15
May 6, 2018 04:38 PM
xach
Offroad & 4x4
Aug 27, 2002 05:34 PM
