I've got a standard flywheel that I'm pretty sure is off of a 351w.
Does anyone have a resource for the number? C8AE-8380-C
Can you see balance (imbalance) weight on a standard flywheel?
Thanks, Ron
Just went through this myself.
Yes you can see the cast in counter-weight part of the flywheel.
I took my casting numbers to the ford parts department, and they ran it through their parts computer and gave me all the info I needed. And it was faster than an internet search!!!
Are you doing an engine swap, or just replacing your flywheel?
Good Luck.
Thinking about an engine swap. Kinda doing a little inventory to see what Iv'e got and what I need. Thanks for the reply, I'll check with the ford house. Ron
