66 F100 / 351W & C6 Transmission - Which Flywheel?
Hi,
I have been searching and searching but it has come to an information overload at this point.
I have a 66 F-100 that has a 351 Windsor installed in it. The engine seems to have come from a 71 Torino (Casting Code: DlOE-6016-AA) and the C6 is a monster transmission C6.
I will be removing an old 4 in the floor standard transmission so I can not reuse that flywheel.
I found a flywheel at autozone and it is the correct 28oz balanced flywheel. However, what diameter would I be looking for and what would the tooth cont need to be?
Here is the autozone link to the flywheel: Pioneer/Flywheel - Automatic Transmission (FRA-205) | 1971 Ford Torino 8 Cylinders H 5.8L 2BL | AutoZone.com
Thanks
Thanks
Thanks NumberDummy, your a huge help. I will probably be needing your help with part numbers a lot more in the coming months.
rubydist - Thanks for the info. The one at autozone is the 164 and it says it replaces Ford part # EOAZ-6375-A which matches what NumberDummy said. I also looked at an 85 351W and the flywheel said it replaced Ford part #D1ZZ-6375-A which is also the number that NumberDummy stated above.
I assume that would mean either flywheel would work for my setup.
If the applications states C6, then it's C6 only. OP's 351W block casting number prefix is D1OE, which could refer to 1971 or 1972.
BushyTee: Where did you get that crap 1985 351W info from? As you can see, D1ZZ-6375-A was NOT replaced by another part number!
I apologize NumberDummy as I probably phrased my previous post wrong.
I just ment that the part autozone sells says it is a replacment for a ford flywheel with the part number #D1ZZ-6375-A.
My 351W shows to be from a 71 Torino but I just searched an 85 351W just to compare it to the replacement for a 71 351W.
Thanks,
Mike
Thanks,
Mike
1981 F100
01-08-2019 06:34 PM
BushyTea
01-25-2015 07:14 PM
Boss50
05-19-2006 08:32 AM
